Learn how to automate sending WhatsApp messages to IndiaMART leads in the semiconductor industry using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To begin automating WhatsApp messages to IndiaMART leads, you need to access Pabbly Connect. First, visit the Pabbly Connect website and log in to your account. If you are a new user, you can sign up for free and get 100 free tasks each month.
After logging in, you will see all the applications available. Click on the Pabbly Connect icon to access the dashboard. Here, you can create workflows that automate your processes, such as sending WhatsApp messages when a new lead is generated.
To automate the WhatsApp messaging process, you need to create a new workflow. Click on the Pabbly Connect dashboard’s top right corner button labeled Create Workflow. A dialog box will prompt you for a workflow name and folder selection.
  • Name your workflow: Send WhatsApp message to IndiaMART leads.
  • Select the folder: Choose IndiaMART Automations from the dropdown.
After entering the details, click the Create button. Your workflow is now set up and ready for the next steps in the automation process.
3. Setting Up Trigger: IndiaMART
In this section, you will configure the trigger for your workflow. Select Pabbly Connect as the trigger application. For the trigger event, choose New Leads from IndiaMART. This means that every time a new lead is generated, it will trigger the automation.
To connect IndiaMART to Pabbly Connect, you will need to copy the provided webhook URL. Go to your IndiaMART account, navigate to the Lead Manager, and select the Push API option. Here, paste the webhook URL and save it.
  • Choose the source name as Pabbly Connect.
  • Click save and confirm your integration setup.
Once the webhook is added successfully, test the connection by generating a test lead in your IndiaMART account. This will confirm that Pabbly Connect is capturing the lead data correctly.
4. Setting Up Action: Sending WhatsApp Messages
Next, you will set up the action step in your workflow. For the action application, select Pabbly Connect and choose WhatsApp by AI Sensei as the action event. This allows you to send a WhatsApp message using the template you have created.
Click the Connect button to establish a connection. You will need to enter your API key from your AI Sensei account. Navigate to your AI Sensei account, go to the Manage section, and find the API key. Copy it and paste it into Pabbly Connect.
Create a campaign name for the WhatsApp message. Map the mobile number and lead name from the previous step.
After mapping the necessary fields, click on Save and Send Test Request. You should now receive the WhatsApp message confirming the integration is successful.
5. Conclusion: Automating WhatsApp Messages with Pabbly Connect
In conclusion, using Pabbly Connect to automate sending WhatsApp messages to IndiaMART leads in the semiconductor industry streamlines your communication process. By following these steps, you can ensure timely responses to inquiries, enhancing customer satisfaction.
This automation not only saves time but also increases efficiency, allowing you to focus on your core business activities while Pabbly Connect handles the integration seamlessly.
