Learn how to automate sending WhatsApp messages to IndiaMART leads for your sanitary ware business using Pabbly Connect. Step-by-step tutorial included. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start sending WhatsApp messages to IndiaMART leads, you first need to access Pabbly Connect. This platform enables seamless integration between IndiaMART and WhatsApp, allowing for automated messaging.
Visit the Pabbly Connect website by entering the URL in your browser. You will see options to sign in or sign up. If you are a new user, click on ‘Sign Up for Free’ to create an account and receive 100 free tasks each month.
2. Setting Up Your Workflow in Pabbly Connect
After logging into Pabbly Connect, navigate to the dashboard and click on the ‘Create Workflow’ button. You will be prompted to name your workflow, such as ‘Send WhatsApp Message to IndiaMART Leads’. Organizing your workflows into folders can help manage multiple automation tasks.
  • Click on ‘Create’ after naming your workflow.
  • Select ‘IndiaMART’ as your trigger application.
  • Choose the event ‘New Lead’ to capture inquiries.
Once you configure the trigger, you will receive a webhook URL. This URL will be used to connect IndiaMART to Pabbly Connect and capture lead details automatically.
3. Configuring IndiaMART to Use Webhook
To connect IndiaMART with Pabbly Connect, navigate to your IndiaMART account. Go to the Lead Manager section, and under the menu, select ‘Push API’.
  • Deactivate any existing webhook before adding a new one.
  • Enter ‘Pabbly Connect’ as the CRM platform name.
  • Paste the copied webhook URL into the Webhook Listener URL field.
After saving these details, generate an OTP to activate the webhook. This establishes a connection between IndiaMART and Pabbly Connect, allowing lead data to flow seamlessly.
With the webhook set up, it’s time to send WhatsApp messages using Pabbly Connect. Select ‘WhatsApp by AI Sensei’ as your action application. Choose the action event as ‘Send Template Message’.
To establish the connection, you will need an API key from AI Sensei. Navigate to your AI Sensei account, go to the manage section, and copy the API key. Paste this key into Pabbly Connect to create the connection.
Provide the campaign name linked to your message template. Map the dynamic phone number of the lead to send messages to. Use template parameters for personalized messaging.
Click on ‘Save and Send Test Request’ to check if the WhatsApp message is sent successfully. You should receive a confirmation message indicating success.
5. Conclusion: Automating Communication with Pabbly Connect
By following these steps, you can effectively automate sending WhatsApp messages to your IndiaMART leads using Pabbly Connect. This integration not only saves time but also enhances communication with potential customers in your sanitary ware business.
Automating your messaging process ensures that you can respond to inquiries promptly, improving customer satisfaction and potentially increasing sales. Utilize Pabbly Connect for seamless integrations and efficient business operations.
