Learn how to automate sending WhatsApp messages to IndiaMART leads for your firecrackers business using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To automate sending WhatsApp messages to IndiaMART leads, start by accessing Pabbly Connect. This platform enables seamless integration between various applications, including WhatsApp and IndiaMART.
Log into your Pabbly Connect account. If you are a new user, you can sign up for free and get 100 tasks each month. Once logged in, you will see the dashboard where you can create workflows.
In this step, you will create a workflow to send WhatsApp messages. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard.
- Enter a name for your workflow, such as ‘Send WhatsApp Message to IndiaMART Leads’.
- Select a folder to save your workflow.
- Click the ‘Create’ button to finalize your workflow setup.
Your workflow is now set up in Pabbly Connect, ready to capture leads from IndiaMART.
3. Setting the Trigger for New Leads in Pabbly Connect
The next step is to set the trigger for your workflow. Select IndiaMART as the trigger application. This allows Pabbly Connect to capture new leads generated through your IndiaMART account.
Choose the trigger event as ‘New Leads’. This means that every time a new lead is generated, Pabbly Connect will activate the workflow. You will receive a webhook URL from Pabbly Connect that you need to copy and paste into your IndiaMART account.
4. Integrating IndiaMART with Pabbly Connect
Log into your IndiaMART account and navigate to the lead manager section. From there, go to ‘Import/Export Leads’ and select the ‘Push API’ option. This is where you will set up the connection to Pabbly Connect.
- Select ‘Other’ as the source.
- Enter ‘Pabbly Connect’ as the source name.
- Paste the webhook URL you copied from Pabbly Connect.
Click the ‘Save Details’ button to complete the integration. Now, Pabbly Connect is ready to receive lead information from IndiaMART.
5. Sending WhatsApp Messages to Leads
After setting up the trigger, it’s time to configure the action step to send WhatsApp messages. Select ‘WhatsApp by AI Sensei’ as your action application in Pabbly Connect.
Choose the action event as ‘Send Template Message’. Enter the campaign name and map the mobile number and lead name from the previous step, ensuring each message is personalized.
Map the mobile number to the lead’s contact information. Map the lead’s name to personalize the message. Click ‘Save and Test Request’ to send the message.
Check your WhatsApp to confirm that the message has been sent successfully. With this setup, Pabbly Connect effectively automates the communication process with your leads.
In this tutorial, we explored how to use Pabbly Connect to send WhatsApp messages to IndiaMART leads for your firecrackers business. By following these steps, you can automate your lead communication efficiently and effectively.
