Learn how to automate WhatsApp messages to IndiaMART leads for your solar energy business using Pabbly Connect. Follow our step-by-step guide for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To send WhatsApp messages to IndiaMART leads for your solar energy business, the first step involves accessing Pabbly Connect. You can do this by searching for ‘Pabbly Connect’ in your web browser. Once on the Pabbly Connect page, you will see options to either sign in or sign up for free.
If you are a new user, click on the ‘Sign Up for Free’ option to receive 100 tasks for free each month. As an existing user, click ‘Sign In’ to access your dashboard. From the dashboard, select ‘Access Now’ under Pabbly Connect to create your automation workflow.
After accessing Pabbly Connect, you can create a new workflow. Click on the blue button labeled ‘Create Workflow’. You will be prompted to name your workflow and select a folder for it. For this tutorial, name the workflow ‘How to Send WhatsApp Message to IndiaMART Leads’ and save it in your desired folder.
- Select ‘IndiaMART’ as your trigger application.
- Choose ‘New Leads’ as the trigger event.
By selecting ‘New Leads’, Pabbly Connect will generate a webhook URL that you will use to connect your IndiaMART account.
3. Connecting IndiaMART with Pabbly Connect
To establish a connection between IndiaMART and Pabbly Connect, you need to copy the generated webhook URL. Log into your IndiaMART account and navigate to the ‘Lead Manager’ section. From there, click on the three dots for ‘Import/Export Leads’ and select ‘Push API’.
- Select ‘Other’ as the source.
- Enter ‘Pabbly Connect’ as the CRM platform name.
- Paste the copied webhook URL in the designated field.
After saving the details, you will generate an OTP to finalize the connection. Enter the OTP and submit to complete the integration process. This will activate the connection between your IndiaMART account and Pabbly Connect.
Once the connection is established, you can set up the action to send WhatsApp messages. In the action step of Pabbly Connect, select ‘AIS Sensi’ as your action application. Choose ‘Send Template Message’ as the action event. This allows you to automate the WhatsApp message sending process.
To connect your AIS Sensi account, you will need an API key. Log into AIS Sensi, navigate to the ‘Manage’ section, and generate your API key. Copy this key and paste it into Pabbly Connect to establish the link. After connecting, select the campaign name that you have created for your solar energy business.
5. Mapping Data for Dynamic Messaging
Mapping data is crucial for sending personalized WhatsApp messages. In Pabbly Connect, map the mobile number and name fields from the previous response to ensure that the messages are personalized for each lead. This means that instead of typing static information, you will dynamically insert the lead’s details.
Map the lead’s mobile number from the previous response. Map the lead’s name for personalized messaging.
Finally, click on ‘Save and Send Request’ to send the WhatsApp message. You should receive confirmation that the message was sent successfully. This completes the automation process, allowing you to send WhatsApp messages to IndiaMART leads automatically.
This tutorial demonstrates how to use Pabbly Connect to automate WhatsApp messages for leads generated through IndiaMART in your solar energy business. By following these steps, you can ensure prompt communication with your leads, enhancing engagement and driving better business outcomes.
