Learn how to automate sending WhatsApp messages to IndiaMART leads for your fertilizer business using Pabbly Connect. Follow our step-by-step tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
Access Pabbly Connect to Automate WhatsApp Messaging
To begin automating WhatsApp messages for IndiaMART leads, first, access Pabbly Connect. This powerful integration platform allows seamless connectivity between your IndiaMART account and WhatsApp Cloud API.
Log into your existing Pabbly Connect account or sign up for free to get started. Once logged in, navigate to the dashboard to create a new workflow specifically for sending WhatsApp messages to your leads generated through IndiaMART.
Creating a Workflow in Pabbly Connect for IndiaMART Leads
After accessing Pabbly Connect, click on the ‘Create Workflow’ button in the dashboard. You will be prompted to name your workflow; for example, name it ‘Send WhatsApp Message to IndiaMART Leads’. This helps in identifying the purpose of the automation.
Next, select a folder to save this workflow. This organization helps manage multiple workflows effectively. After naming and selecting the folder, click on the ‘Create’ button to initiate the workflow setup.
- Name your workflow clearly for easy identification.
- Select a specific folder to keep your workflows organized.
Once the workflow is created, you will see two sections: Trigger and Action. The Trigger section captures the event that initiates the workflow, while the Action section defines what happens in response.
Setting Up the Trigger for New Leads in IndiaMART
In the Trigger section, select IndiaMART as the application. The event you want to capture is ‘New Lead’. This means every time a new lead is generated in your IndiaMART account, it will trigger the workflow.
Pabbly Connect will generate a unique webhook URL, which you need to copy. This URL will connect your IndiaMART account to Pabbly Connect. Log into your IndiaMART account and navigate to the Lead Manager section, where you can set up the webhook.
- Select ‘Push API’ under the Import/Export Leads option.
- Paste the copied webhook URL into the appropriate field.
After saving the changes in IndiaMART, return to Pabbly Connect to test if the connection is successful. Generate a test lead in your IndiaMART account to confirm that the webhook captures the lead details.
Setting Up the Action to Send WhatsApp Messages
Once the trigger is successfully set up, proceed to the Action section in Pabbly Connect. Choose Pabbly Chatflow as the application to send WhatsApp messages. The action event should be set to ‘Send Template Message’.
Click on the connect button, where you will provide your API token from your Pabbly Chatflow account. This token allows Pabbly Connect to send messages on your behalf. Make sure to map the recipient’s mobile number and the message template you want to send.
Ensure you have created a message template in Pabbly Chatflow before this step. Map the lead’s mobile number correctly to avoid delivery issues.
After mapping the necessary fields, click on ‘Save and Send Test Request’ to send a test message. Check your WhatsApp to confirm that the message has been received successfully.
Using Pabbly Connect, you can efficiently automate sending WhatsApp messages to IndiaMART leads for your fertilizer business. This integration streamlines communication, ensuring timely responses to inquiries and enhancing customer engagement.
