Learn how to automate sending WhatsApp messages to Facebook leads for your renewable energy business using Pabbly Connect. Step-by-step guide included. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To begin the process of sending WhatsApp messages to Facebook leads, you first need to access Pabbly Connect. This platform allows you to create automated workflows that connect various applications, including WhatsApp and Facebook Lead Ads.
Start by visiting the Pabbly Connect website. If you already have an account, click on ‘Sign In’. If you are a new user, click on ‘Sign Up Free’ to create your account. You will receive 100 free tasks each month upon signing up, which is a great way to get started.
Once you are logged into Pabbly Connect, you will need to create a new workflow. Click on the ‘Create Workflow’ button, then name your workflow something descriptive, such as ‘Send WhatsApp Message to Facebook Leads for Renewable Energy Business’.
- Click on the folder icon to create a new folder.
- Select the folder you just created for better organization.
- Click on ‘Create’ to finalize your workflow setup.
After naming your workflow, you will reach a new window where you can set up the trigger and action applications. In this case, your trigger application will be Facebook Lead Ads, and the action application will be WhatsApp Cloud API.
3. Setting Up the Trigger with Facebook Lead Ads
In this step, you will configure the trigger for your workflow using Pabbly Connect. Select ‘Facebook Lead Ads’ as your trigger application, then choose the trigger event ‘New Lead Instant’. This option ensures that a WhatsApp message is sent immediately after a new lead is generated.
Next, you will need to connect your Facebook account to Pabbly Connect. Click on ‘Connect’ and select ‘Add New Connection’. Follow the prompts to authorize your Facebook account and select the appropriate Facebook page and lead generation form.
- Ensure your lead ads form is live to receive data correctly.
- Test the connection by clicking ‘Save and Send Test’ to confirm data flow.
After completing these steps, you should see a confirmation that the trigger has been successfully set up in Pabbly Connect.
4. Configuring the Action with WhatsApp Cloud API
Now it’s time to set up the action for your workflow using Pabbly Connect. Select ‘WhatsApp Cloud API’ as your action application and choose the action event ‘Send Template Message’. This will allow you to send pre-defined messages to your leads.
To connect your WhatsApp Cloud API account, click on ‘Connect’ and select ‘Add New Connection’. You will need to enter your temporary access token, phone number ID, and WhatsApp Business Account ID. This information can be found in your WhatsApp Cloud API settings.
Fill in the required fields with the correct information. Select your message template from the available options. Map the recipient’s mobile number and other variables accordingly.
After saving your action setup, you can test the workflow by sending a WhatsApp message to verify that everything is functioning correctly.
With both the trigger and action set up in Pabbly Connect, it’s time to finalize the integration. Click on ‘Save and Send Test’ to send a test message to the WhatsApp number you specified. Ensure that you enter the recipient’s number without the plus sign and include the country code.
Once you have sent the test message, check your WhatsApp account to confirm that the message was received successfully. If everything works correctly, your setup is complete, and you can now automatically send WhatsApp messages to new leads generated from your Facebook ads.
In summary, this integration process between Facebook Lead Ads and WhatsApp Cloud API using Pabbly Connect allows you to streamline your communication with potential customers. By following these steps, you can ensure that every new lead receives timely follow-up messages, enhancing your customer engagement.
This tutorial demonstrates how to effectively automate sending WhatsApp messages to Facebook leads using Pabbly Connect. By following the detailed steps outlined, you can enhance your renewable energy business communication effortlessly.
