Learn how to automate sending WhatsApp messages to Facebook leads for your sand and gravel business using Pabbly Connect. Follow our step-by-step tutorial for seamless integration.
1. Accessing Pabbly Connect for Your Sand & Gravel Business
Pabbly Connect is essential for automating WhatsApp messages to Facebook leads for your sand and gravel business. To get started, open a new tab and visit the Pabbly Connect website. using Pabbly Connect
Once there, you can either sign in if you already have an account or sign up for free. Signing up takes just a few minutes, and you receive 100 free tasks monthly. After logging in, click on the ‘Access Now’ button under Pabbly Connect to reach the dashboard.
Creating a workflow is the next step in using Pabbly Connect for your sand and gravel business. Click on the ‘Create Workflow’ button on the dashboard. A window will pop up, prompting you to name your workflow. using Pabbly Connect
  • Name your workflow, such as ‘Send WhatsApp Messages to Facebook Leads’.
  • Select a folder to save your workflow, preferably one related to Facebook Lead Ads.
After naming and selecting the folder, click on ‘Create’. You’ll now see the trigger and action sections where you can set up the automation process.
3. Setting Up the Trigger with Facebook Lead Ads
For your sand and gravel business, the trigger application in Pabbly Connect will be Facebook Lead Ads. Select Facebook Lead Ads as your trigger application. using Pabbly Connect
Next, you need to choose the trigger event. Click on the dropdown and select the ‘New Lead Instant’ option. Connect your Facebook account by clicking ‘Connect’, then ‘Add New Connection’. Once connected, select your Facebook page, such as ‘Sand Castle Solutions’, and choose the lead generation form you want to use.
4. Configuring the Action to Send WhatsApp Messages
After setting up the trigger, it’s time to configure the action in Pabbly Connect using WhatsApp Cloud API. Select WhatsApp Cloud API as your action application and choose ‘Send Template Message’ as the action event. using Pabbly Connect
To connect WhatsApp Cloud API, you’ll need to provide your Access Token, Phone Number ID, and WhatsApp Business Account ID. You can find these details in your WhatsApp Cloud API account. Once you have entered the details, click on ‘Save’ to establish the connection.
  • Make sure to refresh your Access Token before using it.
  • Ensure that your WhatsApp message template is approved by Meta.
After saving the connection, you can map the recipient’s mobile number and the body of the message using data from the Facebook lead.
5. Testing the Integration with Sample Leads
Once everything is set up, it’s crucial to test the integration to ensure it works flawlessly. You can create a sample lead using the Meta for Developers tool to submit dummy details. using Pabbly Connect
After submitting the sample lead, return to Pabbly Connect and click on ‘Save and Send Test Request’. If configured correctly, you should receive a positive response indicating the message has been sent. Check your WhatsApp to confirm the automated message has been delivered successfully.
Repeat this process by creating new leads to verify that the automation works consistently. Each time a new lead is generated from Facebook Lead Ads, an automated WhatsApp message will be sent, streamlining your communication for your sand and gravel business.
In this tutorial, we detailed how to use Pabbly Connect to automate sending WhatsApp messages to Facebook leads for your sand and gravel business. By following these steps, you can enhance your lead response time and improve customer engagement.
