Learn how to automate sending WhatsApp messages to Facebook leads for sustainable products using Pabbly Connect. Follow our detailed tutorial for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start sending WhatsApp messages to Facebook leads for sustainable products, you first need to access Pabbly Connect. Go to the Pabbly Connect homepage by browsing to the URL Pabbly.com/connect. You will see options to sign in or sign up.
If you are new, click on the ‘Sign Up Free’ button to create an account. Existing users can simply click on ‘Sign In’. Once logged in, you will be directed to the Pabbly Connect dashboard, where you can create workflows to automate your processes.
In this step, you will create a new workflow in Pabbly Connect to automate the sending of WhatsApp messages. Click on the ‘Create Workflow’ button located at the top right corner of your dashboard.
  • Name your workflow ‘Green Horizon Facebook Lead Ads to WhatsApp Message’.
  • Select a folder for better organization, such as ‘Facebook Lead Ads to WhatsApp’.
  • Click the ‘Create’ button to finalize your workflow setup.
This workflow will consist of a trigger and an action. The trigger will be set to ‘Facebook Lead Ads’ and the action will be ‘WhatsApp Cloud API’ to send messages automatically whenever there is a new lead.
3. Setting Up the Trigger for Facebook Leads
To set up the trigger in Pabbly Connect, select ‘Facebook Lead Ads’ as the trigger application. Choose the trigger event as ‘New Lead Instant’. This configuration ensures that whenever a new lead is generated, Pabbly Connect captures the response immediately.
Next, click on ‘Connect’ to establish a new connection with your Facebook account. If your account is already connected, you can select the existing connection. After establishing the connection, select your Facebook page named ‘Green Horizons’ and then choose your lead form, such as ‘Organic Product Form’.
4. Setting Up the Action with WhatsApp Cloud API
The next step involves setting up the action in Pabbly Connect. Select the action application as ‘WhatsApp Cloud API’ and the action event as ‘Send Template Message’. Click on ‘Connect’ to create a new connection with your WhatsApp Cloud API account.
Here, you will need to enter your temporary access token, phone number ID, and WhatsApp Business Account ID. If you do not have these details, you need to set up your WhatsApp Cloud API account in the Meta for Developers platform.
  • Copy the required details from your WhatsApp Cloud API account.
  • Paste them into the respective fields in Pabbly Connect.
  • Select your message template, such as ‘Facebook Leads Message’.
Ensure that you map the recipient’s mobile number and any dynamic fields in your template to personalize the message sent to new leads.
5. Testing the Automation Setup
After setting up the trigger and action in Pabbly Connect, it’s crucial to test the automation to ensure it works correctly. Use the lead testing tool to delete any previous test leads and create a new lead submission.
Fill out the form with dummy data and submit it. Once submitted, check your WhatsApp to confirm that the automated message has been received. The message should reflect the details entered, demonstrating that the integration is functioning as intended.
By following these steps, you can successfully automate the process of sending WhatsApp messages to your Facebook leads for sustainable products using Pabbly Connect. Make sure to monitor the workflow for any adjustments needed.
In this tutorial, we learned how to send WhatsApp messages to Facebook leads for sustainable products using Pabbly Connect. By automating this process, you can enhance your customer engagement and streamline your marketing efforts efficiently.
