Learn how to automate WhatsApp messages to Facebook leads for your pest control business using Pabbly Connect. Step-by-step guide included. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To send automated WhatsApp messages to Facebook leads for your pest control business, you first need to access Pabbly Connect. Start by signing in or creating a new account on the Pabbly website, where you can get 100 free tasks every month.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow by clicking the ‘Create Workflow’ button. This is where you will set up the integration between Facebook lead ads and WhatsApp.
In your Pabbly Connect dashboard, click on the ‘Create Workflow’ button. Name your workflow something descriptive, such as ‘Send WhatsApp Message to Facebook Leads’. Save your workflow in a folder named ‘Facebook Lead Ads’ for better organization. using Pabbly Connect
- Click on ‘Create’ to proceed with your new workflow.
- You will see options for setting up a trigger and an action.
In the trigger section, select ‘Facebook Lead Ads’ as your trigger application. Choose the event ‘New Lead Instant’ to ensure that the workflow runs whenever a new lead is received.
To establish a connection between Facebook Lead Ads and Pabbly Connect, click on the ‘Connect’ button. A prompt will appear asking you to log in to your Facebook account if you haven’t already done so.
Once connected, select the Facebook page associated with your pest control business and the corresponding lead form. After making your selections, click on ‘Save and Send Test Request’ to test the integration.
- Ensure you have created a lead form named ‘Pest Control Contact Form’ on your Facebook page.
- The response should show that a new lead has been captured successfully.
This step confirms that your trigger is working and will capture leads in real-time.
4. Sending WhatsApp Messages through Pabbly Connect
After successfully capturing leads, the next step is to send an automated WhatsApp message. To do this, select ‘WATI’ as your action application in Pabbly Connect. Choose the action event ‘Send Template Message’ to set up the WhatsApp message.
Connect WATI to Pabbly Connect by entering the API endpoint and access token from your WATI account. This ensures that Pabbly Connect can send messages through WhatsApp.
Map the WhatsApp number from the Facebook lead response. Select the template you created for Facebook leads.
After mapping the necessary fields, click on ‘Save and Test Request’ to send a test message. If successful, you will see that the WhatsApp message has been sent to the test lead.
Using Pabbly Connect, you can seamlessly integrate Facebook Lead Ads with WhatsApp to automate your pest control business messaging. This setup allows you to efficiently engage with leads and enhance customer communication.
