Learn how to send WhatsApp messages to Facebook leads for your matrimony business using Pabbly Connect. Step-by-step guide with detailed instructions. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To send WhatsApp messages to Facebook leads for your matrimony business, you need to start by accessing Pabbly Connect. If you are an existing user, simply sign in. New users can click on the ‘Sign Up for Free’ button to create an account and get 100 tasks for free each month.
Once logged in, navigate to the applications page, and click on Pabbly Connect to access your dashboard. Here, you will create a new workflow specifically for sending WhatsApp messages to Facebook leads in your matrimony business.
Creating a New Workflow in Pabbly Connect
In your Pabbly Connect dashboard, locate the ‘Create Workflow’ button in the top right corner. Click on it to initiate the process of creating a new workflow. Name your workflow as ‘Send WhatsApp Messages to Facebook Leads for Matrimony Business’. This name will help you identify the workflow later.
After naming your workflow, you will be directed to a window that allows you to set up the trigger and action. The trigger application will be Facebook Lead Ads, and the trigger event will be ‘New Lead Instant’. This means that whenever a new lead is generated through Facebook, your workflow will automatically trigger.
  • Click on ‘Create’ after naming your workflow.
  • Select Facebook Lead Ads as your trigger application.
  • Choose ‘New Lead Instant’ as the trigger event.
Once you have set up your trigger, you can proceed to the action application. Here, you will select the WhatsApp Cloud API to send messages to the leads captured from Facebook.
Connecting Facebook Lead Ads to Pabbly Connect
To establish a connection between Facebook Lead Ads and Pabbly Connect, click on the ‘Connect’ button in the trigger setup. You will need to log into your Facebook account if you haven’t already done so.
After successfully connecting, select the Facebook page associated with your matrimony business. For instance, if your page is named ‘Soulmates Matrimony’, search for and select it. Then, choose the lead generation form linked to this page. In this case, select the form named ‘Contact Form Soulmates Matrimony’.
  • Click ‘Save and Send Test Request’ to verify the connection.
  • Ensure the lead form is correctly set up in your Facebook business account.
After saving, Pabbly Connect will wait for a webhook response. This means you need to conduct a test submission to ensure that the integration is working as expected.
Testing the Integration and Sending WhatsApp Messages
To test the integration, go to the Meta for Developers page and access the Lead Ads Testing Tool. From the dropdown, select your Facebook page and the associated lead form. Fill out the lead form with sample data, including email, full name, phone number, and gender, then submit the form.
Once the submission is successful, return to Pabbly Connect. You should see the captured lead details such as email, full name, phone number, and gender displayed on your dashboard. This confirms that the first step of the automation is complete.
Verify that the lead information appears in the Pabbly Connect interface. Ensure that the workflow is triggered automatically upon receiving new lead data.
Now, you can proceed to send a WhatsApp message using the WhatsApp Cloud API. This involves establishing a connection between WhatsApp Cloud API and Pabbly Connect by entering your API token and other required details.
Finalizing WhatsApp Message Setup in Pabbly Connect
To finalize the WhatsApp message setup, click on ‘Connect’ in the action setup of Pabbly Connect. Enter your WhatsApp Cloud API token, phone number ID, and WhatsApp Business Account ID. These details can be obtained from the Meta for Developers dashboard.
Once you have successfully connected, select the message template you created earlier, such as ‘New Lead Message’. This template contains a customizable variable for the lead’s name, ensuring that each message is personalized.
Choose the template name and confirm the language code. Map the recipient’s mobile number to ensure it pulls from the lead data.
After mapping the necessary fields, click on ‘Save and Test Request’. If successful, you will receive a confirmation that a WhatsApp message has been sent to the lead. This indicates that your automation is fully operational.
In this tutorial, we explored how to send WhatsApp messages to Facebook leads for your matrimony business using Pabbly Connect. By following the steps outlined, you can automate your communication with leads effectively, enhancing your business engagement.
