Learn how to send WhatsApp messages to Facebook leads for your matrimony business using Pabbly Connect. Step-by-step guide for seamless integration. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To send WhatsApp messages to Facebook leads for your matrimony business, you need to access Pabbly Connect. Start by signing in to your existing account or clicking on the ‘Sign Up for Free’ button if you are a new user. Once logged in, navigate to the applications page.
On the applications page, click on Pabbly Connect to reach your dashboard. Here, you can create a new workflow by clicking the ‘Create Workflow’ button. Name your workflow something like ‘Send WhatsApp Messages to Facebook Leads for Matrimony Business’ and click on ‘Create’ to proceed.
2. Setting Up Trigger and Action in Pabbly Connect
In Pabbly Connect, the next step is to set up the trigger and action applications. For this integration, your trigger application will be Facebook Lead Ads, and the action application will be WhatsApp via the WhatsApp Cloud API. Select Facebook Lead Ads as your trigger application and choose the ‘New Lead Instant’ event.
  • Select Facebook Lead Ads as the trigger application.
  • Choose the ‘New Lead Instant’ trigger event.
  • Set WhatsApp as the action application with ‘Send Template Message’ as the action event.
Once you have set up the trigger and action, click on ‘Connect’ to establish a connection between Facebook Lead Ads and Pabbly Connect. This connection is crucial for the automation process to work effectively.
3. Connecting Facebook Leads to Pabbly Connect
To connect your Facebook Leads to Pabbly Connect, you need to log into your Facebook account. Click on ‘Connect’ in the Pabbly Connect interface, and select the Facebook page associated with your matrimony business. Make sure to choose the correct lead generation form that corresponds to your page.
  • Select your Facebook page, such as ‘Soulmates Matrimony’.
  • Choose the associated lead gen form, like ‘Contact Form Soulmates Matrimony’.
  • Click ‘Save and Send Test Request’ to initiate the connection.
After saving, Pabbly Connect will wait for a webhook response. To test this, you can submit a lead through the Facebook lead form, which will then capture the lead information in Pabbly Connect.
Once the lead information is captured in Pabbly Connect, the next step is to send a WhatsApp message. To do this, you need to establish a connection between WhatsApp Cloud API and Pabbly Connect. Click on ‘Connect’ and enter the required details such as the access token, phone number ID, and WhatsApp business account ID.
Copy the access token from your WhatsApp Cloud API setup. Paste the phone number ID and WhatsApp business account ID in the respective fields. Click ‘Save’ to establish the connection.
After the connection is established, select the message template you want to use for sending WhatsApp messages. Ensure to map the lead’s phone number dynamically so that each new lead receives a personalized message.
5. Conclusion: Automating Communication with Pabbly Connect
In conclusion, using Pabbly Connect to send WhatsApp messages to Facebook leads for your matrimony business streamlines your communication process. By following the steps outlined in this tutorial, you can automate the workflow effectively, ensuring that every new lead receives timely information through WhatsApp.
This integration not only enhances customer engagement but also saves valuable time. With Pabbly Connect, you can focus more on growing your matrimony business while automating essential communications.
