Learn how to integrate WhatsApp Cloud API and Facebook Lead Ads for the Cement Industry using Pabbly Connect in this step-by-step tutorial. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for Cement Industry Automation
To start sending WhatsApp messages to Facebook leads for the cement industry, you first need to access Pabbly Connect. Begin by visiting the Pabbly Connect website and signing in to your account. If you are a new user, you can sign up for free and receive 100 tasks each month.
Once logged in, you will see the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. This is essential for automating the process of sending WhatsApp messages whenever a new lead is generated from your Facebook lead ads.
Creating a workflow in Pabbly Connect is crucial for the integration process. After clicking on ‘Create Workflow’, a dialog box will prompt you to name your workflow. Name it something like ‘PTI Simmons Facebook Leads to WhatsApp Message’. Select a folder to save your workflow, which can be created by clicking on the plus button.
  • Click on ‘Create’ to finalize your workflow.
  • You will see two windows: Trigger and Action.
  • The trigger will be set to Facebook Lead Ads.
After setting up the workflow, you need to configure the trigger step. Click on the arrow next to the trigger section and select Facebook Lead Ads as your trigger application. Choose the trigger event as ‘New Lead Instant’ to ensure that every new lead is captured automatically.
3. Connecting Facebook Lead Ads with Pabbly Connect
Next, you must connect Facebook Lead Ads to Pabbly Connect. After selecting Facebook Lead Ads as the trigger, click on the ‘Connect’ button. A new window will appear where you can choose to add a new connection. If you have previously logged into your Facebook account, this process will be straightforward.
Once connected, select the Facebook page associated with your cement business, such as ‘Better Build Cement’. Afterward, choose the lead form you created for capturing leads. This ensures that Pabbly Connect will capture the necessary details from the leads generated through your ads.
4. Setting Up WhatsApp Cloud API in Pabbly Connect
After configuring the trigger, it’s time to set up the action step using Pabbly Connect. Click the arrow in the action section and select WhatsApp Cloud API as the action application. Choose the action event as ‘Send Template Message’. This allows you to send a pre-defined message to leads captured from Facebook.
  • Connect to WhatsApp Cloud API by adding a new connection.
  • Input the required details such as token, phone number ID, and WhatsApp account ID.
  • Map the recipient’s mobile number and the message template you created.
After entering all the necessary details, click on ‘Save and Send Test Request’. This will send a test message to ensure that the integration works correctly. You should receive a WhatsApp message confirming the successful setup.
5. Testing the WhatsApp Integration with Pabbly Connect
Finally, you need to test the integration to ensure everything functions as intended. Use the Facebook lead ads testing tool to generate a test lead. Select the appropriate page and lead form, fill in the required details, and submit the form.
Once the test lead is submitted, check your WhatsApp to see if the message was received. If everything is set up correctly, you will receive a WhatsApp message with the details from the lead, confirming that Pabbly Connect has successfully automated the process of sending messages to your leads.
In this tutorial, we demonstrated how to send WhatsApp messages to Facebook leads for the cement industry using Pabbly Connect. By following these steps, you can automate communication with your leads effectively, enhancing your business operations.
