Learn how to automate WhatsApp messages on successful Instamojo payments using Pabbly Connect. Follow this detailed tutorial step-by-step for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Setting Up Pabbly Connect for WhatsApp Messaging
To send WhatsApp messages on successful Instamojo payments, you first need to set up Pabbly Connect. This powerful automation tool enables seamless integration between Instamojo and WhatsApp Cloud API. Start by visiting the Pabbly Connect website and either sign in or sign up for a free account.
Once logged in, navigate to the dashboard. Here, you can create a new workflow by clicking the ‘Create Workflow’ button. Name your workflow, for example, ‘Send WhatsApp Message on Successful Instamojo Payments’, and select a folder for organization.
2. Creating a Trigger in Pabbly Connect
The next step involves setting up the trigger in Pabbly Connect. Click on the trigger window and search for Instamojo as your trigger application. Select it and choose the trigger event as ‘New Sale’. This event will activate whenever a successful payment is processed.
  • Search for Instamojo in the trigger application.
  • Choose ‘New Sale’ as the trigger event.
  • This will start the automation on a successful payment.
After setting the trigger, Pabbly Connect will provide a webhook URL. This URL is crucial as it connects your Instamojo account with Pabbly Connect. Copy the webhook URL and proceed to your Instamojo account to paste it in the appropriate field under the product settings.
3. Connecting Instamojo with Pabbly Connect
Now that you have the webhook URL from Pabbly Connect, go to your Instamojo dashboard. Under the product you wish to connect, scroll to the Advanced settings and find the Webhook URL field. Paste the copied URL here to establish the connection.
Once you save the changes, Instamojo will send payment notifications to Pabbly Connect via the webhook. You can now test this setup by making a purchase through your e-commerce store. Ensure the payment is successful to trigger the automation.
4. Setting Up WhatsApp Cloud API in Pabbly Connect
After confirming that the webhook is working, the next step is to set up WhatsApp Cloud API in Pabbly Connect. You will select WhatsApp Cloud API as your action application and choose the action event as ‘Send Template Message’. This will allow you to send customized messages to customers.
  • Select WhatsApp Cloud API as the action application.
  • Choose ‘Send Template Message’ as the action event.
  • Connect your WhatsApp Cloud API account by entering the required credentials.
In this step, you will need to input your WhatsApp Business Account ID, Phone Number ID, and Access Token. These credentials can be obtained from your WhatsApp Cloud API setup. After entering these details, click on Save to establish the connection.
5. Sending WhatsApp Message on Successful Payment
With both the trigger and action set up in Pabbly Connect, you can now send WhatsApp messages automatically. Select the message template you want to use for notifications. Ensure the template includes placeholders for dynamic data like customer name and payment details.
Map the relevant fields from the Instamojo response to the WhatsApp message template. This mapping ensures that every time a payment is received, the correct information is sent to the customer. Test the entire setup by processing a new payment and confirming that the WhatsApp message is sent successfully.
In this tutorial, we explored how to use Pabbly Connect to automate sending WhatsApp messages on successful Instamojo payments. By following these steps, you can enhance customer communication and streamline your payment processing workflow effectively.
