Learn how to automate sending TradingView alerts to Slack using Pabbly Connect. This step-by-step guide covers all necessary integrations. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To automate sending TradingView alerts to Slack, we will use Pabbly Connect. First, open your browser and go to the Pabbly Connect website. You can sign up for a free account or log in if you already have one.
Once logged in, navigate to the ‘All Apps’ page and click on ‘Access Now’ under Pabbly Connect. This will take you to the Pabbly Connect dashboard where you can create your automation workflow.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ button. Name your workflow, for example, ‘TradingView to Slack’. Select the appropriate folder for your workflow and click on ‘Create’. using Pabbly Connect
  • Enter a descriptive name for your workflow.
  • Choose the folder where the workflow will be saved.
  • Click on ‘Create’ to start building your automation.
Your workflow will now display two windows: the trigger window and the action window. In the trigger window, select ‘TradingView’ as the app and choose ‘New Alert’ as the trigger event.
3. Connecting TradingView to Pabbly Connect
After selecting TradingView, you will receive a webhook URL. This URL is essential for connecting your TradingView alerts to Pabbly Connect. Copy this webhook URL and go to your TradingView account.
Open the alert you created in TradingView and paste the webhook URL in the notification section. Make sure to set the alert condition to trigger when the stock price crosses up a specific value. Click on ‘Save’ to finalize this setup.
4. Setting Up a Filter in Pabbly Connect
To ensure only relevant alerts are sent to Slack, we need to set up a filter in Pabbly Connect. After the trigger, click on ‘Add Action Step’ and select ‘Filter by Pabbly’.
  • Choose the response label from the TradingView trigger.
  • Select ‘Contains’ as the filter type.
  • Enter ‘Crossing up’ as the filter value.
This filter will ensure that only alerts containing the phrase ‘Crossing up’ will be sent to your Slack channel. Click on ‘Save’ to apply the filter settings.
5. Sending Alerts to Slack
Next, we need to set up the action to send messages to Slack. Click on ‘Add Action Step’ and select ‘Slack’ from the app options. Choose ‘Send Channel Message’ as the action event. using Pabbly Connect
Connect your Slack account by clicking on ‘Connect with Slack’. You will have the option to choose either a user-based or bot-based connection. For automation purposes, a bot-based connection is recommended. After connecting, select the channel where alerts should be sent.
Map the message content from the TradingView alert to the Slack message field. This ensures that the exact alert message from TradingView is sent to Slack. Finally, click on ‘Save’ and test the automation to see if the alerts are being sent successfully.
In this tutorial, we explored how to use Pabbly Connect to automate sending TradingView alerts to Slack. By following the steps outlined, you can efficiently keep your team informed about important trading signals in real-time.
