Learn how to send Telegram notifications for ScoreApp quiz responses using Pabbly Connect. Step-by-step guide on setting up this integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Accessing Pabbly Connect for Telegram Notifications
To send Telegram notifications for ScoreApp quiz responses, start by accessing Pabbly Connect. This platform enables seamless integration between ScoreApp and Telegram, automating your notification process.
Begin by visiting the Pabbly Connect website. If you don’t have an account, sign up for free, which grants you 100 tasks monthly. Once signed in, navigate to the Pabbly Connect dashboard where you can create workflows to automate tasks.
In this section, we will create a workflow that connects ScoreApp to Telegram using Pabbly Connect. Click on the ‘Create Workflow’ button to initiate the process.
  • Name your workflow, for example, ‘Send Telegram Notification for ScoreApp Quiz Responses’.
  • Select a folder to save your workflow, such as ‘Home’.
  • Click on ‘Create’ to proceed to the workflow setup.
After creating the workflow, you will see two boxes: Trigger and Action. The Trigger is the event that starts the workflow, while the Action is what happens as a result. Here, we set ScoreApp as the Trigger application.
The next step involves setting up the Trigger and Action in Pabbly Connect. Select ScoreApp as your Trigger application and choose the event ‘Quiz Finished’.
To connect ScoreApp with Pabbly Connect, you will need a webhook URL. Copy the webhook URL provided by Pabbly Connect and navigate to your ScoreApp settings to integrate the webhook.
  • Go to the Integrate section in ScoreApp.
  • Select Webhooks and click on ‘Connect’.
  • Paste the copied webhook URL and save the settings.
Now that the Trigger is set up, you need to test it by submitting a quiz in ScoreApp. Once a quiz is submitted, Pabbly Connect will capture the response, confirming that the integration is working.
4. Sending Telegram Notifications Using Pabbly Connect
With the Trigger set up, the next step is to configure the Action to send notifications on Telegram using Pabbly Connect. Select Telegram as the Action application and choose the event ‘Send Text Message’.
To connect Telegram, you will need a bot token. Create a new bot using the BotFather in Telegram, and copy the generated token back to Pabbly Connect.
Search for BotFather in Telegram to create a new bot. Provide a name and username for your bot, ensuring the username ends with ‘_bot’. Copy the token provided and paste it into Pabbly Connect.
After connecting the bot, you need to specify the chat ID where notifications will be sent. Create a group in Telegram, add your bot as an admin, and retrieve the chat ID from the group URL. Paste this chat ID into Pabbly Connect.
5. Finalizing and Testing Telegram Notifications
In this final section, you will finalize the setup for sending Telegram notifications using Pabbly Connect. Construct the message that will be sent when a quiz is submitted, including user details such as name and email.
Map the user details from the quiz response in Pabbly Connect to the message text. Once you have configured the message, save the settings and test the request to ensure it works correctly.
Click on ‘Save and Test Request’ in Pabbly Connect. Check your Telegram group for the notification message. Verify that the message contains the correct user details.
By following these steps, you have successfully set up an automated Telegram notification system for ScoreApp quiz submissions using Pabbly Connect. This integration allows you to receive real-time updates on quiz responses.
In this tutorial, we explored how to send Telegram notifications for ScoreApp quiz responses using Pabbly Connect. By automating this process, you can efficiently manage quiz submissions and stay informed about user interactions.
