Learn how to automate SMS sending to MagicBricks leads using Pabbly Connect and ClickSend. Follow our step-by-step guide for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Accessing Pabbly Connect for SMS Integration
To send SMS to MagicBricks leads, you first need to access Pabbly Connect. This integration platform allows you to automate SMS sending efficiently. Start by creating a free account on Pabbly Connect, which takes just two minutes to set up.
Once logged in, navigate to the dashboard. Click on the blue button labeled ‘Create Workflow’ to begin setting up your automation. You can name your workflow something like ‘Send SMS to MagicBricks Leads Automatically’ and select a folder for organization. After that, click on ‘Create’ to proceed with the integration.
2. Setting Up Trigger and Action in Pabbly Connect
In this step, you will set up the trigger and action for your workflow in Pabbly Connect. The trigger will be set to capture new leads from MagicBricks, while the action will be sending an SMS via ClickSend. This means that every time a new lead is captured, an SMS will be sent automatically.
  • Select MagicBricks as your trigger application.
  • Choose ‘New Leads’ as the trigger event.
  • Copy the provided webhook URL for configuration.
After copying the webhook URL, you will need to reach out to your account manager at MagicBricks to activate this integration. Once they enable it, new lead data will start flowing into Pabbly Connect, allowing you to automate SMS sending seamlessly.
3. Capturing Lead Data from MagicBricks
Once the webhook is set up, Pabbly Connect will capture lead data whenever a new lead arrives. This includes essential information like the lead’s name, phone number, and email address. You’ll see a response indicating that the connection is working correctly.
For demonstration, a dummy lead may show data such as:
This data confirms that the integration between MagicBricks and Pabbly Connect is functioning as intended. You can now proceed to set up the SMS action.
4. Sending SMS via ClickSend through Pabbly Connect
Now that you have captured the lead data, it’s time to send an SMS using ClickSend through Pabbly Connect. Select ClickSend as your action application and choose the ‘Send SMS’ action event. This will initiate the SMS sending process.
To connect ClickSend, you will need to provide your API credentials. Access the developer menu in ClickSend to retrieve your username and API key. After entering these details in Pabbly Connect, you can map the lead’s phone number and compose the SMS message.
Map the phone number from the lead data. Compose your SMS message, including personalized elements like the lead’s name. Click ‘Save and Send Test Request’ to test the SMS sending.
After saving, you should receive a confirmation that the SMS was sent successfully. This concludes the SMS setup process using Pabbly Connect and ClickSend.
5. Conclusion: Automate SMS Sending to MagicBricks Leads
In conclusion, using Pabbly Connect to integrate SMS sending to MagicBricks leads is a straightforward process. By following the steps outlined, you can automate your SMS communication efficiently. This integration saves time and ensures that your leads receive timely information.
With Pabbly Connect, you can manage your lead communication effortlessly, allowing you to focus on other important aspects of your real estate business. Automate your workflows today for better productivity!
