Learn how to send SMS for Landingi form submissions using Pabbly Connect. This detailed tutorial covers step-by-step integration with SMS services. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Accessing Pabbly Connect for SMS Integration
To send SMS for Landingi form submissions, the first step is to access Pabbly Connect. You can do this by visiting the Pabbly Connect homepage. Here, you will find options to sign in or sign up for free.
If you are a new user, click on the ‘Sign Up for Free’ button to create an account. Once registered, you will receive 100 free tasks monthly, allowing you to explore the functionalities of Pabbly Connect without any cost.
After signing in, navigate to the dashboard of Pabbly Connect. Here, you can create a new workflow by clicking on the ‘Create Workflow’ option. You will be prompted to name your workflow; enter ‘Send SMS for Landingi Form Submission’.
- Select the folder to save your workflow.
Once the workflow is created, you will see two windows: one for the trigger and one for the action. The trigger is set to ‘Landing G’ while the action will be handled by ‘Twi’ for sending SMS. This setup is crucial for automating the SMS sending process.
3. Setting Up the Trigger with Landingi Forms
In the trigger section, select ‘Landing G’ as your application. The trigger event will be set to ‘New Lead Form Submission’. This event signifies that whenever a form is submitted, the workflow will initiate.
After selecting the trigger event, Pabbly Connect will provide you with a webhook URL. This URL is essential for connecting your Landingi account to Pabbly Connect.
- Copy the webhook URL.
- Navigate to your Landingi account to integrate this URL.
In Landingi, go to the form settings, select integrations, and add the copied webhook URL. Set the request method to POST and save your changes. This connection ensures that data from Landingi is sent to Pabbly Connect whenever a form is submitted.
4. Configuring the Action to Send SMS via Twilio
Next, set up the action in your Pabbly Connect workflow. Choose ‘Twilio’ as your action application. The action event will be ‘Send SMS Message’. This step is critical for sending SMS notifications to users who fill out the form.
To configure Twilio, enter your Account SID, Auth Token, and Twilio phone number. These details can be found in your Twilio account. Once you have entered the necessary information, click on ‘Save’.
Enter the body of the SMS you wish to send. Map the recipient’s phone number from the previous Landingi form submission.
For example, you can customize the SMS message to include the user’s name. This dynamic mapping ensures that each SMS sent is personalized based on the form submission.
5. Testing the Integration and Finalizing
After setting up both the trigger and action, it’s time to test the integration. Go back to your Landingi form and submit a test entry. Ensure to include dummy data such as a name, email, and phone number.
Once the form is submitted, return to Pabbly Connect. You should see that the response from Landingi has been captured successfully. This indicates that the connection is working as intended.
Finally, send a test SMS from Twilio to verify that the SMS is being sent correctly to the submitted phone number. If everything is set up properly, you should receive the SMS confirming the form submission.
Using Pabbly Connect, you can seamlessly automate SMS notifications for Landingi form submissions. This integration allows you to enhance user engagement by sending personalized SMS messages instantly.
