Learn how to send SMS notifications for Cloudwaitress restaurant orders using Pabbly Connect. Step-by-step guide for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Accessing Pabbly Connect for SMS Integration
To send SMS notifications for Cloudwaitress restaurant orders, start by accessing Pabbly Connect. This platform is essential for integrating the SMS service with your Cloudwaitress account.
First, navigate to the Pabbly website. If you don’t have an account, sign up for free. Once logged in, click on the Access Now button under Pabbly Connect to reach the dashboard where you can create workflows.
In this section, you will create a new workflow to automate SMS notifications for new orders. Click on the Create Workflow button on your Pabbly Connect dashboard.
- Name your workflow, for example, ‘Send SMS for Cloudwaitress Orders’.
- Select a folder to save your workflow.
- Click on Create to proceed.
This setup will allow you to define the trigger and action for the workflow. Ensure you select the correct folder to keep your workflows organized.
3. Setting Up the Trigger for New Orders
The next step is to set up the trigger in your workflow. For this integration, the trigger application will be Cloudwaitress. Select it and choose the event as New Order Placed.
After selecting the trigger event, you will receive a webhook URL from Pabbly Connect. This URL is crucial as it will connect Cloudwaitress to Pabbly Connect.
- Go to your Cloudwaitress account settings.
- Paste the webhook URL in the appropriate section under webhook settings.
Once the webhook is set up, Cloudwaitress will send new order data to Pabbly Connect whenever an order is placed.
4. Sending SMS Notifications Using Pabbly Connect
Now, let’s configure the action step to send SMS notifications using Pabbly Connect. After the trigger is set, select Tulio as the action application.
You will then need to choose the action event as Send SMS Message. Connect Tulio to Pabbly Connect by entering your account SID and authorization token from your Tulio account.
Provide the SMS body that includes customer details and order information. Map the customer’s name, restaurant name, and delivery address from the Cloudwaitress response. Ensure the recipient’s mobile number includes the country code.
After setting up these details, save the configuration. The system will automatically send SMS notifications to customers upon receiving new orders.
5. Testing the Integration and Final Setup
After configuring the workflow, it’s essential to test the integration to ensure everything works correctly. Place a test order through Cloudwaitress to trigger the SMS notification.
Check your SMS inbox to verify that the message was sent correctly. The SMS should include the order details and customer information as set up in the previous steps.
If the SMS is received, your integration is successful. If not, revisit the steps to ensure all configurations are correct.
With this, you have successfully integrated SMS notifications for Cloudwaitress restaurant orders using Pabbly Connect.
In this tutorial, we explored how to send SMS notifications for Cloudwaitress restaurant orders using Pabbly Connect. This integration automates customer communication, ensuring they receive timely updates about their orders.
