Learn how to automate Slack notifications for received KrispCall SMS using Pabbly Connect. Step-by-step tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for SMS Automation
To automate the process of sending Slack notifications for received KrispCall SMS, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in or signing up for a free account.
Once logged in, you will be directed to your dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. This is where you will set up the integration between KrispCall and Slack.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ button. Name your workflow something descriptive, like ‘Send Slack Notification for Received KrispCall SMS’. You can also choose a folder to save your workflow. using Pabbly Connect
- Select ‘KrispCall’ as your trigger application.
- Choose ‘New SMS’ as the trigger event.
After setting the trigger, you will need to set the action application. Select Slack and the action event as ‘Send Channel Message’. This establishes the connection needed for the automation.
3. Connecting KrispCall to Pabbly Connect
To connect KrispCall with Pabbly Connect, you will need your API key and secret. Go to your KrispCall account settings, navigate to the developer section, and copy both keys.
Return to Pabbly Connect, click on ‘Connect’, and paste the API key and secret key into the respective fields. After entering the keys, click on ‘Save’ to establish the connection. This allows Pabbly Connect to capture new SMS data in real-time.
4. Sending Notifications to Slack
After setting up the connection with KrispCall, it’s time to configure the Slack integration. Click on ‘Connect’ for Slack and select the bot token type. After saving, grant the necessary permissions for your workspace. using Pabbly Connect
- Choose the Slack channel where notifications will be sent.
- Frame the message to be sent, including the inquirer’s phone number and message content.
Utilizing mapping, insert the dynamic data from the SMS response into your message. Click ‘Save and Send Request’ to send the message to Slack, confirming the successful integration.
5. Testing and Confirming the Integration
To ensure everything is working correctly, send a test SMS through KrispCall. This SMS should trigger the workflow in Pabbly Connect, capturing the details of the message.
Once the SMS is received, check your Slack channel for the notification. The message should include the inquirer’s phone number and any additional details you’ve mapped. This confirms that the integration is functioning as intended.
Using Pabbly Connect, you can seamlessly automate Slack notifications for received KrispCall SMS. This integration enhances communication and ensures your team is promptly informed of new inquiries.
