Learn how to send Slack notifications for new GoHighLevel contacts using Pabbly Connect. Follow our step-by-step tutorial for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To send Slack notifications for GoHighLevel contacts, we start by accessing Pabbly Connect. First, open a new tab and search for Pabbly Connect. You can either sign in or sign up for free if you don’t have an account yet.
Once logged in, you will see the dashboard where you can manage your workflows. Click on the ‘Access Now’ button under Pabbly Connect to start creating your integration.
In Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button and name your workflow ‘Send Slack Notification for GoHighLevel Contact’.
- Name the workflow appropriately.
- Select the folder to save the workflow.
- Click ‘Create’ to proceed.
Now, you will see two boxes labeled Trigger and Action. The Trigger will be GoHighLevel, and the Action will be Slack. Set up the trigger first by selecting GoHighLevel and the event ‘Contact Created’.
3. Connecting GoHighLevel to Pabbly Connect
To connect GoHighLevel with Pabbly Connect, you will need to use a webhook URL. This URL acts as a bridge between the two applications. Copy the webhook URL provided in Pabbly Connect.
Next, go to your GoHighLevel account, navigate to Automation, and create a new workflow. Add a trigger for ‘Contact Created’ and name it accordingly. Then, add a webhook action and paste the copied URL into the URL section. Save and publish the workflow.
4. Creating a New Contact in GoHighLevel
After setting up the webhook, it’s time to test the integration by creating a new contact in GoHighLevel. Click on the plus button to add a new contact. Fill in the details such as first name, last name, email, and phone number.
- First Name: New
- Last Name: Contact
- Email: [email protected]
- Phone: +91 1234567890
Once you save the contact, GoHighLevel will send the contact details to Pabbly Connect via the webhook, allowing you to proceed to the next step.
5. Sending a Notification to Slack
Now, return to Pabbly Connect to set up the action for sending a Slack notification. Select Slack as the action application and choose ‘Send Channel Message’ as the action event.
Connect your Slack account by selecting the token type as bot and allowing access. Choose the channel where you want to send the notification, such as the General channel.
Compose your message using the mapped fields from the GoHighLevel response. Include the contact’s name, phone number, and email. After setting up the message, click ‘Save and Send Test Request’ to verify that the notification is sent successfully.
In this tutorial, we demonstrated how to send Slack notifications for new GoHighLevel contacts using Pabbly Connect. By following these steps, you can automate notifications and enhance your workflow efficiency.
