Learn how to send Slack notifications for new SendPulse subscribers using Pabbly Connect. This tutorial provides step-by-step instructions for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To send Slack notifications for new SendPulse subscribers, we first need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing into your account. If you are a new user, you can sign up for free and get 100 free tasks every month.
Once logged in, navigate to the Pabbly Connect dashboard. This is where you can create workflows that automate tasks between applications. Click on the ‘Create Workflow’ button to get started with your automation process.
In this section, we will create a workflow specifically for sending Slack notifications when a new subscriber is added in SendPulse. Click on the ‘Create Workflow’ button in the top right corner, and a dialog box will appear asking for the workflow name. using Pabbly Connect
- Name your workflow: ‘Send Slack Notification for SendPulse Subscriber’.
- Select a folder to save your workflow.
After naming your workflow and selecting a folder, click on the ‘Create’ button. You will see two windows labeled ‘Trigger’ and ‘Action’. The trigger is what starts the automation, and the action is what happens as a result.
3. Setting Up Trigger with SendPulse
To set up the trigger, click on the dropdown menu in the trigger application section and select ‘SendPulse’. For the trigger event, choose ‘New Subscriber’. This means that every time a new subscriber is added to your SendPulse account, the automation will activate.
Next, you will need to connect SendPulse to Pabbly Connect by using a webhook URL provided by Pabbly. Copy this URL and log into your SendPulse account. Go to the account settings and find the API section to create a new webhook.
- Click on ‘API’ in the account settings.
- Select ‘Webhooks’ and click on ‘Create a Webhook’.
- Paste the copied Pabbly Connect webhook URL and save.
After saving, go back to your Pabbly Connect workflow and click on ‘Recapture Webhook Response’ to ensure the connection is successful.
4. Setting Up Action with Slack
With the trigger set up, it’s time to configure the action. For the action application, select ‘Slack’ and choose the action event as ‘Send Channel Message’. This action will send a notification to your specified Slack channel whenever a new subscriber is created in SendPulse.
Click on the ‘Connect’ button to link your Slack account with Pabbly Connect. A new window will appear prompting you to add a new connection. Choose the token type as ‘Bot’ and authorize the connection.
Select your Slack channel (e.g., ‘New SendPulse Subscribers’). Compose the message to be sent, including subscriber details.
Map the data from the previous step (SendPulse) into the message. This way, every time a new subscriber is added, the relevant details will be dynamically included in the Slack notification.
5. Testing the Automation
After configuring both the trigger and action, it’s essential to test the automation. Create a test subscriber using the SendPulse form you set up earlier. Once the subscriber is created, return to your Pabbly Connect workflow. using Pabbly Connect
Check if the webhook response has been captured successfully. If the details of the new subscriber appear correctly, this indicates that the integration is functioning as intended. Finally, verify that the Slack channel received the notification with the subscriber details.
This testing process ensures that your workflow is set up correctly and that you will receive notifications for new subscribers in real-time.
In this tutorial, we learned how to send Slack notifications for new SendPulse subscribers using Pabbly Connect. By following the steps outlined, you can automate notifications and streamline your communication process effectively.
