Learn how to send Slack notifications for failed Instamojo payments using Pabbly Connect. Follow our step-by-step tutorial to set up your integration easily. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To send Slack notifications for failed Instamojo payments, the first step is to access Pabbly Connect. This integration platform allows you to connect your Instamojo account with Slack seamlessly. If you are a new user, you can sign up for free and receive 100 tasks to get started.
Once signed up, log in to your Pabbly Connect account. On the dashboard, locate the ‘Create Workflow’ button on the right side. Click this button to initiate the workflow setup process for sending notifications about failed payments.
After clicking on ‘Create Workflow’, you will need to name your workflow. For this integration, name it ‘Send Slack Notification for Failed Instamojo Payment’. This helps in identifying your workflow easily in the future.
  • You will now see the trigger and action setup window.
In this window, select Instamojo as the trigger application. Choose the trigger event as ‘New Sale’. This event is crucial as it triggers the workflow when a payment is made, whether successful or failed. Next, you will configure the webhook URL provided by Pabbly Connect to capture payment details.
3. Setting Up Instamojo for Payment Notifications
To connect your Instamojo account with Pabbly Connect, you need to set up a payment page. Navigate to your Instamojo account and create a new payment link. Enter the payment purpose and amount (e.g., 800 INR) as required.
  • Add the webhook URL from Pabbly Connect to your payment link.
  • Save the payment link to finalize the connection.
With this setup, every transaction will send data back to Pabbly Connect, allowing you to capture both successful and failed payment notifications. Test this by making a dummy payment and entering incorrect details to simulate a failed transaction.
4. Filtering for Failed Payments in Pabbly Connect
Once you have set up your payment link, the next step in Pabbly Connect is to filter for failed payments. After receiving the webhook data, use the ‘Filter by Pabbly’ action to set conditions.
Select the status label and set the condition to ‘failed’. Map the payment ID from the previous response.
This filter ensures that only failed transactions trigger the Slack notification. Save the filter settings and proceed to the next action step where you will retrieve payment details from Instamojo using the ‘Get Payment Details’ action.
5. Sending Slack Notifications for Failed Payments
In this final step, use Pabbly Connect to send a notification to your Slack channel. Search for Slack in the action application and select ‘Send Channel Message’. Connect your Slack account by authorizing the application to post messages.
Choose the channel where notifications will be sent (e.g., ‘failed payments’). Compose your message including dynamic fields such as name, email, phone, and payment ID.
After mapping the required fields, save the action and test the workflow. Once the test is successful, you will see the notification appear in your selected Slack channel whenever a payment fails in Instamojo. This completes your integration using Pabbly Connect.
By following these steps, you can effectively use Pabbly Connect to send Slack notifications for failed Instamojo payments. This integration ensures that you stay informed about payment issues, allowing for timely customer support and resolution.
