Learn how to automate Mailmodo campaigns on Elementor form submissions using Pabbly Connect. Step-by-step guide for seamless integration. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect for Mailmodo Integration
To start automating Mailmodo campaigns on Elementor form submission, first access Pabbly Connect. Open your browser and type in Pabbly.com/connect. This platform is essential for linking Elementor forms with Mailmodo campaigns.
Once on the Pabbly Connect page, you will see options to sign in or sign up. Existing users can sign in directly, while new users can click on ‘Sign up for free’ to create an account. This offers 100 free tasks each month, making it easy to get started with automation.
After signing in, navigate to your Pabbly Connect dashboard. Click on the ‘Create Workflow’ button in the top right corner. Name your workflow something descriptive, like ‘Send Mailmodo Campaigns on Elementor Form Submission’. using Pabbly Connect
  • Select a folder to save your workflow, such as ‘Elementor Mailmodo Automation’.
  • Click ‘Create’ to proceed to the trigger and action setup.
You will now see the trigger and action setup window. The trigger application is set to Elementor, and the action application is Mailmodo. This setup is crucial for automating the process of sending campaigns when a form is submitted.
In the trigger section, search for Elementor as your application. The trigger event should be set to ‘New Form Submission’. This means every time a new form is submitted through Elementor, it will initiate the workflow.
Once the trigger is configured, you will be given a webhook URL. This URL is critical as it connects your Elementor form with Pabbly Connect. You will need to copy this URL to set it up in your Elementor form.
4. Configuring Your Elementor Form to Use Pabbly Connect
Edit the form you created using Elementor. In the Elementor editor, go to the ‘Actions After Submit’ section and add the ‘Webhook’ action. Paste the webhook URL you copied from Pabbly Connect into the designated field. using Pabbly Connect
  • After pasting the URL, click on ‘Update’ to save changes to your form.
  • Now, your Elementor form is connected to Pabbly Connect and is ready to send submissions.
Once updated, Pabbly Connect will wait for a webhook response, indicating that the form is ready to capture data from submissions. You can now proceed to test the integration by submitting the form.
5. Integrating Mailmodo with Pabbly Connect
To complete the automation, go back to Pabbly Connect and configure the action application as Mailmodo. Select the action event as ‘Trigger Campaign’. This will send the Mailmodo campaign upon receiving a new form submission. using Pabbly Connect
Next, you need to connect your Mailmodo account with Pabbly Connect. For this, you will require your Mailmodo API key. Go to your Mailmodo account settings, navigate to API keys, and create a new key. Copy this key and paste it into Pabbly Connect to establish the connection.
Once connected, you will need to specify the campaign ID for the campaign you want to send. This ID can be found in your Mailmodo account under the campaigns section. After mapping the email and any personalization fields, click ‘Save and Test’. A successful response will indicate that your setup is complete, and the automation is now live.
Using Pabbly Connect to automate Mailmodo campaigns on Elementor form submissions streamlines your marketing efforts. This integration ensures that every form submission triggers a personalized campaign, enhancing user engagement effectively.
