Learn how to send LinkedIn leads to other applications using Pabbly Connect. This detailed tutorial covers each step for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To begin, access Pabbly Connect by signing in or creating a new account. This platform enables seamless integration of LinkedIn leads with other applications.
Once you are logged in, you will see the dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Follow the prompts to set up your automation.
After accessing Pabbly Connect, the next step is to create a workflow that will automate the process of sending LinkedIn leads to another application. Click on the ‘Create Workflow’ button.
- Name your workflow according to its purpose, such as ‘Send LinkedIn Leads to Other Applications’.
- Select the trigger application, which in this case is LinkedIn Lead Generation Forms.
- Choose the trigger event as ‘New Lead Generation Form Response’.
Once you have configured these settings, click on ‘Save’ to proceed. This setup allows Pabbly Connect to monitor for new leads generated through your LinkedIn forms.
3. Setting Up the Trigger for LinkedIn Leads
The trigger in this integration is the LinkedIn Lead Generation Forms. This step is crucial as it determines how Pabbly Connect will receive data from LinkedIn.
After selecting the trigger, you will need to connect your LinkedIn account. Click on ‘Connect’ and select ‘Add New Connection’. Follow the prompts to authorize Pabbly Connect to access your LinkedIn account.
Once connected, select the specific lead generation form you wish to use. Ensure that you have created this form in LinkedIn beforehand. This will allow Pabbly Connect to fetch new leads from the selected form seamlessly.
4. Setting Up Action Using API in Pabbly Connect
Next, we will set up the action step in Pabbly Connect. Since Miller Lite does not have a native integration, we will use the API feature. Select ‘API by Pabbly’ as your action application.
- Choose the action event as ‘Create Subscriber’.
- Enter the Endpoint URL and set the request method to ‘POST’.
- Select the payload type as ‘JSON’.
Finally, configure the authentication settings by entering your API token from the Miller Lite account. This allows Pabbly Connect to send lead data securely to Miller Lite.
5. Mapping Data in Pabbly Connect
Once the action settings are configured, you need to map the lead data from LinkedIn to the corresponding fields in Miller Lite. This is where Pabbly Connect shines, allowing dynamic data transfer.
For each field in Miller Lite, such as email, first name, and last name, ensure you map the values from the LinkedIn lead response. This mapping ensures that every new lead is correctly captured in Miller Lite.
After mapping all necessary fields, click on ‘Save and Send Test Request’ to verify that the integration works. Check your Miller Lite account to confirm that the new subscriber has been added successfully. This confirms that Pabbly Connect has successfully automated the process of sending LinkedIn leads to Miller Lite.
In this tutorial, we explored how to send LinkedIn leads to other applications using Pabbly Connect. By following these steps, you can automate lead management effectively, enhancing your business processes.
