Learn how to automate sending Instagram lead ads leads to a Telegram group using Pabbly Connect. Step-by-step guide included. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Accessing Pabbly Connect for Instagram Lead Ads and Telegram Group Integration
To send Instagram lead ads leads to a Telegram group, you first need to access Pabbly Connect. Begin by typing in the URL Pabbly.com/connect
in your browser. This will take you to the Pabbly Connect dashboard where you can either sign in or sign up for free.
After signing in, navigate to the Pabbly Connect section. Here, you will find the options to create a new workflow. Click on the Create Workflow
button and name your workflow appropriately, such as ‘Send Instagram Lead Ads Lead to Telegram Group’. This setup is crucial as you will use it to automate the integration process.
2. Setting Up Trigger and Action in Pabbly Connect
In this step, you will define the trigger and action for your automation using Pabbly Connect. The trigger application is Instagram Lead Ads, and the action application is Telegram. Select Instagram Lead Ads as your trigger application and the event as New Lead Instant
. This means the workflow will activate whenever a new lead is generated through your Instagram ads.
- Select Instagram Lead Ads as the trigger application.
- Choose the trigger event as New Lead Instant.
- Confirm the selection to proceed with the setup.
Next, move to the action window and search for Telegram as your action application. Select Telegram Bot
as the action application and choose the action event as Send Text Message
. This setup ensures that when a new lead is captured, the details will be sent to your Telegram group automatically.
3. Connecting Instagram Lead Ads to Pabbly Connect
To establish a connection between Instagram Lead Ads and Pabbly Connect, you will need to click on the Connect
button. This connection is made through your Facebook account, which is linked to your Instagram account. Click on Continue
to authorize the connection.
Once the authorization is successful, you will need to select the Facebook page associated with your Instagram ads. After selecting your page, choose the lead form you are using to generate leads. Click on Save
and then Send Test Request
to ensure the connection is working properly.
4. Setting Up Telegram Bot for Message Delivery
Now, it’s time to connect your Telegram bot to Pabbly Connect. To do this, you need to create a new bot using Telegram’s BotFather. Send a message to BotFather with the command /newbot
to create your bot. Follow the prompts to name your bot and choose a username.
Once your bot is created, you will receive a token. Copy this token and paste it into Pabbly Connect to establish the connection. You will also need to enter the chat ID of the Telegram group where you want to send the messages. After setting up the bot and chat ID, ensure to add the bot to your Telegram group and give it admin rights to send messages.
5. Finalizing the Integration Setup in Pabbly Connect
With the connections established, you can now finalize the integration setup in Pabbly Connect. Create the message format you wish to send to your Telegram group by mapping the lead details from the previous steps. This mapping allows the automation to dynamically insert the lead information into the message.
- Frame the message to include lead details like name, email, and phone number.
- Use mapping to insert dynamic data from the lead.
- Test the setup by clicking
Save and Send Test Request
After testing, check your Telegram group to ensure the message was received successfully. This confirms that the integration is working as intended, and now every new lead from your Instagram ads will be sent directly to your Telegram group.
In conclusion, using Pabbly Connect to send Instagram lead ads leads to a Telegram group automates your workflow efficiently. By following the steps outlined, you can seamlessly integrate these applications for better lead management.
