Learn how to send IndiaMART leads to other applications using API by Pabbly Connect. Follow our step-by-step tutorial to automate your workflow effectively. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
Accessing Pabbly Connect for IndiaMART Integration
To begin the process of sending IndiaMART leads to other applications, first access Pabbly Connect. This platform allows you to automate workflows between various applications seamlessly. If you are a new user, you can sign up for free and get 100 free tasks every month, or you can sign in if you already have an account.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new folder for your workflow. Click on the folder icon and name it, for example, ‘Automations for IndiaMART.’ After creating your folder, click on the ‘Create Workflow’ button to start setting up your automation.
Setting Up the Trigger with IndiaMART
In this step, we will set up the trigger application using Pabbly Connect. The trigger application is IndiaMART, which will initiate the workflow whenever a new lead is captured. Click on the trigger application option and select ‘IndiaMART’ as your trigger application.
Next, choose the trigger event as ‘New Leads.’ This event will start the workflow when a new lead comes in. After selecting the trigger event, click on ‘Connect’ to add your IndiaMART account. You will need to enter your CRM API key, which you can find by logging into your IndiaMART account and navigating to Settings > Account Settings > CRM API.
Connecting Pabbly Connect to Other Applications via API
After successfully setting up the trigger, we will now configure the action application using Pabbly Connect. The action application will be the API by Pabbly, which acts as a bridge to connect to other applications. Select ‘API by Pabbly’ as your action application and choose the action event as ‘Execute API Request.’
To set this up, you will need to enter several details, including the API endpoint URL. For example, if you are using MailerLite, you can find the API endpoint in their developer documentation. Select the method as ‘POST’ and set the payload type to JSON. You will also need to provide authentication details, which could be a Bearer token obtained from your MailerLite account.
- Select the action event as ‘Execute API Request’.
- Enter the API endpoint URL from MailerLite.
- Choose the payload type as JSON.
After entering these details, click on ‘Save and Send Test Request’ to verify if the setup is correct. If everything is configured properly, you should receive a successful response indicating that the lead details have been sent to the target application.
Mapping Lead Details in Pabbly Connect
In this section, we will map the lead details received from IndiaMART to the API request using Pabbly Connect. This involves adding parameters such as email and status to ensure the correct data is sent to the action application. Start by entering the email label and using the mapping feature to insert the email address from the lead details received.
Similarly, add the status parameter and set its value to ‘Active.’ Click on ‘Save and Send Test Request’ again to check if the mapping works correctly. You should receive a positive response confirming that the lead has been successfully added to the target application.
- Map the email address from the IndiaMART response.
- Set the status parameter to ‘Active’.
- Click ‘Save and Send Test Request’ to verify the mapping.
After confirming the successful addition of the lead, you can check your target application to ensure the subscriber has been added correctly.
Summary of Integrating IndiaMART with Pabbly Connect
In summary, we have successfully set up a workflow using Pabbly Connect to send leads from IndiaMART to another application via API. The process involved setting up a trigger for new leads in IndiaMART and connecting it to an action application using API by Pabbly.
This integration allows you to automate the handling of leads efficiently. By following the steps outlined in this tutorial, you can streamline your workflow and enhance productivity. With Pabbly Connect, you can integrate various applications and automate processes effectively.
In conclusion, using Pabbly Connect to send IndiaMART leads to other applications via API simplifies your workflow. This tutorial provides clear steps to automate your lead management process efficiently.
