Learn how to automate WhatsApp messages for successful Instamojo payments using Pabbly Connect. Step-by-step tutorial with detailed instructions. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To begin the process of sending and receiving WhatsApp messages upon successful Instamojo payments, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect landing page and either sign in or sign up for a free account. If you are a new user, signing up grants you 100 tasks free every month.
After logging in, navigate to the dashboard where you will find various Pabbly applications. Click on the ‘Access Now’ button for Pabbly Connect. This will take you to your workflow dashboard, where you can create a new automation workflow.
In the Pabbly Connect dashboard, start by clicking on the ‘Create Workflow’ button. You will then need to name your workflow. For this tutorial, name it ‘Send & Get WhatsApp Message on Successful Instamojo Payment’. Select a folder to save your workflow, such as ‘Automations’. using Pabbly Connect
- In the workflow window, you will see options for setting up a trigger and action.
- Select ‘Instamojo’ as your trigger application.
After selecting Instamojo, choose ‘Successful Payment’ as the trigger event. This will initiate the workflow each time a successful payment is made. Once selected, Pabbly Connect will generate a Webhook URL that you will need to copy for the next steps.
3. Setting Up Instamojo with Pabbly Connect
To connect Instamojo to Pabbly Connect, log into your Instamojo account and navigate to the page settings where you want to set up the webhook. Locate the ‘Webhooks’ section and enable it by switching it on.
- Paste the copied Webhook URL from Pabbly Connect into the designated field.
- Ensure that you select the option to send only successful payment information.
- Click ‘Save’ to update the page settings.
After saving, return to Pabbly Connect and you will see it waiting for a webhook response. To test the setup, perform a test payment on your Instamojo page. This will trigger the webhook and allow Pabbly Connect to capture the payment details.
Once Pabbly Connect captures the payment details, the next step is to send an automated WhatsApp message. For this, select ‘WhatsApp Cloud API’ as the action application in your workflow. Choose ‘Send Template Message’ as the action event.
You will need to connect your WhatsApp Cloud API account to Pabbly Connect. If you have already set up a connection, select it; otherwise, click on ‘Add New Connection’ and provide the required credentials, including your access token and phone number ID.
Map the recipient’s mobile number from the Instamojo response. Fill in the body fields with dynamic data such as the customer’s name and payment amount. Click ‘Save and Send Request’ to send the message.
After successfully sending the message, you can check your WhatsApp to confirm receipt of the automated message. This process ensures that both customers and your team are notified of new payments seamlessly through Pabbly Connect.
5. Notifying Your Team via WhatsApp
To notify your team about successful payments, you will add another action step in the same workflow. Again, select ‘WhatsApp Cloud API’ and choose ‘Send Template Message’ as the action event.
For this action, you will not map the recipient’s number dynamically. Instead, enter your team’s static mobile number to ensure they receive notifications for every successful payment.
Map the necessary fields such as customer name, email, contact number, and payment amount in the body fields. Click ‘Save and Send Request’ to send the notification to your team. Check your WhatsApp for confirmation of the message sent to your team.
With this setup, your team will be immediately informed of new payments, ensuring efficient communication and management of orders through Pabbly Connect.
In this tutorial, we demonstrated how to automate WhatsApp messages for successful Instamojo payments using Pabbly Connect. By following these steps, you can enhance customer communication and streamline notifications for your team effectively.
