Learn how to send Discord messages for received KrispCall SMS using Pabbly Connect. This detailed tutorial walks you through the integration step-by-step. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect to Set Up Your Integration
To send a message for received KrispCall SMS, you first need to access Pabbly Connect. Open your browser and type in Pabbly.com/connect to reach the landing page.
On this page, you will see options for signing in or signing up. Existing users can click on the sign-in button while new users should select the sign-up option. Pabbly Connect provides 100 free tasks every month for new users, making it easy to get started.
Once signed in, navigate to the dashboard and click on the ‘Create Workflow’ button located in the top right corner. Here, you will need to name your workflow, such as ‘Send Discord Message for Received KrispCall SMS’.
- Choose a suitable folder for your workflow, like ‘Crisp Call to Discord Automation’.
- Click ‘Create’ to proceed to the next step.
Now you will see a new window for configuring your trigger and action. This is where Pabbly Connect facilitates the automation process by allowing you to set up a trigger from KrispCall and an action in Discord.
3. Setting Up the Trigger and Action
In the trigger section, search for ‘KrispCall’ as your trigger application and select the event ‘New SMS’. This event will activate whenever a new SMS is received on your registered number.
Next, for the action application, search for ‘Discord’ and choose the action event ‘Send Channel Message’. This configuration allows Pabbly Connect to send the received SMS directly to your specified Discord channel.
- Click on ‘Connect’ to establish a connection between KrispCall and Pabbly Connect.
- You will need to provide your API key and secret key from your KrispCall account.
Once you’ve entered the keys and saved the settings, you can test the connection to ensure everything is working properly. This step is crucial for the automation to function correctly.
4. Testing the Integration with a Sample SMS
With the trigger and action set up, it’s time to test the integration. Send a sample SMS to the number registered with your KrispCall account. For example, you might send a message saying, ‘Hello, I’m a demo user interested in your services.’ This message is crucial for verifying that your integration works as intended.
After sending the SMS, return to Pabbly Connect and check if the response is captured correctly. You should see the SMS details, including the sender’s phone number and message content.
Ensure that the SMS details are displayed in the response section. This confirms that the trigger is functioning correctly.
Now that you’ve successfully captured the SMS, you can proceed to set up the Discord message that will be sent automatically.
5. Sending the Message to Discord
To send the captured SMS to your Discord channel, you need to create a webhook in Discord. Navigate to your Discord channel settings, go to Integrations, and select Webhooks. Here, you can create a new webhook, naming it something like ‘Captain Hook’.
Once the webhook is created, copy the webhook URL and paste it into Pabbly Connect. In the message field, format your message to include the details of the inquiry. For instance, you might write: ‘Hello team, we have received a new inquiry from {phone_number} with the message: {message_content}.’ This mapping is essential to ensure that each new SMS is sent with the correct details.
After mapping the necessary fields, save your settings and send a test request. Check your Discord channel to verify that the message appears as expected. This confirms that your integration is successful, and now every time you receive a new SMS on your KrispCall number, it will automatically be sent to your Discord channel.
In this tutorial, we explored how to use Pabbly Connect to send Discord messages for received KrispCall SMS. By following the steps outlined, you can automate the process of sending SMS notifications to your team on Discord, enhancing communication and efficiency.
