Learn how to integrate KrispCall SMS with Discord using Pabbly Connect to automate your messaging process effectively. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To send a Discord message for received KrispCall SMS, we start by accessing Pabbly Connect. Open your browser and type in ‘Pabbly.com/connect.’ You will see options to sign in or sign up for free. If you are a new user, click on the ‘Sign up for free’ button to create an account, which allows you 100 free tasks every month.
Once you are signed in, navigate to the Pabbly Connect dashboard. Click on the ‘Access Now’ button to enter your dashboard. From here, you can create a new workflow for automating the message sending process. This is where Pabbly Connect plays a crucial role in connecting KrispCall and Discord seamlessly.
Next, we will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located in the top right corner of your dashboard. A dialog box will appear asking for a workflow name. Name your workflow ‘Send Discord Message for Received KrispCall SMS’ and select the folder to save it in, such as ‘KrispCall to Discord Automation.’ Then, click ‘Create’ to proceed.
  • Select the folder for organization.
After creating the workflow, you will see the trigger and action setup window. The trigger is the event that starts the automation, while the action is what happens after the trigger. This is where Pabbly Connect enables the integration process between KrispCall and Discord.
In this step, we will set up the trigger and action for our automation using Pabbly Connect. Start by selecting KrispCall as the trigger application. The trigger event will be ‘New SMS,’ which activates whenever a new SMS is received on your registered number. Click on the connect button to establish this connection.
Next, you will need to enter your API key and secret key from your KrispCall account. Navigate to your KrispCall settings, go to the developer section, and copy your API key and secret key. Paste them into the respective fields in Pabbly Connect and click ‘Save’ to complete the connection.
4. Testing the Connection and Sending Messages
Once the connection is established, it’s time to test the setup in Pabbly Connect. You will need to send a test SMS to the number registered with your KrispCall account. For instance, send a message that states, ‘Hello, I’m demo user, I would like to know more about your digital marketing services.’ This message will be captured by Pabbly Connect as a response.
After sending the SMS, go back to Pabbly Connect, and you should see the response with the SMS details. This confirms that the trigger is working correctly. Now, we will set up the action to send this SMS content to your Discord channel.
  • Send a test SMS to your KrispCall number.
  • Check for the response in Pabbly Connect.
  • Ensure the trigger captures the SMS correctly.
Once you confirm the SMS is captured, you can proceed to set up the action to send the message to Discord. This step highlights how Pabbly Connect effectively facilitates the entire integration process.
5. Finalizing Discord Integration in Pabbly Connect
To complete the integration, we need to set up Discord as the action application in Pabbly Connect. Select Discord and choose the action event as ‘Send Channel Message.’ Click on connect and enter the webhook URL you copied from your Discord channel settings. This URL is essential for sending messages to the channel.
Next, craft the message you want to send to your Discord channel. For example, you might say, ‘Hello team, we have received a new inquiry from [Phone Number] with the message: [SMS Content].’ Here, you will use the mapping feature in Pabbly Connect to dynamically insert the phone number and SMS content from the previous step. Once everything is set up, click on ‘Save and Send Test Request’ to finalize the integration.
After testing, check your Discord channel to see if the message was sent successfully. This confirms that the integration is working perfectly, showcasing the power of Pabbly Connect in automating your workflow.
By following these steps, you can easily send Discord messages for received KrispCall SMS using Pabbly Connect. This integration automates communication, ensuring that your inquiry handling team stays informed in real-time. Utilize Pabbly Connect to enhance your workflow and streamline your processes effectively.
