Learn how to send automated WhatsApp messages to your modular kitchen business leads using Pabbly Connect. Step-by-step guide to integrate Facebook Lead Ads with WhatsApp API.
To send automated WhatsApp messages to your modular kitchen business leads, the first step is accessing Pabbly Connect. This platform facilitates the integration between Facebook Lead Ads and WhatsApp API, allowing you to automate lead communication effectively.
Start by visiting the Pabbly Connect website. If you don’t have an account, you can sign up for free. This process is quick and provides you with 100 free tasks each month. Once signed in, click on the ‘Access Now’ button under Pabbly Connect to enter the dashboard where you will create your workflow.
After accessing Pabbly Connect, create a new workflow to automate WhatsApp messages. Click on the ‘Create Workflow’ button and name your workflow, such as ‘Send Automated WhatsApp Message to Modular Kitchen Leads’. Select a folder to save it, then proceed to the workflow setup page.
  • Select the folder where you want to save your workflow.
In the workflow setup, you will see two boxes: Trigger and Action. The Trigger application will be Facebook Lead Ads, which initiates the process. Select Facebook Lead Ads and choose the trigger event as ‘New Lead Instant’ to proceed.
In this step, you will connect Facebook Lead Ads to Pabbly Connect. Click on the ‘Connect’ button and add a new connection. Ensure that you have logged into your Facebook account, which allows Pabbly Connect to access your lead ads.
Once connected, you will need to select your Facebook page and lead generation form. For instance, if your page is named ‘Kitchen Cuddles’, select this page and then choose your lead form, such as ‘Contact Form’. After selecting these, click on the ‘Save and Send Test’ button.
4. Sending Automated WhatsApp Messages via Pabbly Connect
Now that you have set up your trigger, the next step is to configure the action for sending WhatsApp messages using Pabbly Connect. Select the action application as Vati, which is the WhatsApp API service, and choose the action event as ‘Send Template Message’. Connect Vati to Pabbly Connect by entering the API endpoint and access token.
To retrieve these details, you need to go to Vati’s API documentation. Copy the API endpoint and access token, and paste them into the respective fields in Pabbly Connect. After connecting, fill in the WhatsApp number using the mapped data from the Facebook lead response, ensuring it corresponds to the lead’s WhatsApp number.
  • Map the WhatsApp number from the Facebook lead data.
  • Select your message template from Vati.
  • Fill in any custom parameters required for the message.
Once all details are filled in correctly, click on the ‘Save and Test’ button to confirm that your automated WhatsApp message is sent successfully. You will receive a positive response indicating the message was sent to your lead.
5. Summary of the Successful Integration Process
In summary, the integration process using Pabbly Connect allows you to automate WhatsApp messaging to your modular kitchen business leads effectively. You started by accessing Pabbly Connect and creating a workflow with Facebook Lead Ads as the trigger.
Next, you connected Facebook Lead Ads to Pabbly Connect to capture lead details. Finally, you configured Vati to send an automated WhatsApp message using the lead information. This workflow ensures instant communication with your leads, enhancing your business efficiency.
Using Pabbly Connect, you can seamlessly integrate Facebook Lead Ads and WhatsApp to send automated messages to your modular kitchen business leads. This process enhances communication and improves lead engagement effectively.
