Learn how to automate your WhatsApp messaging for marble and granite business leads using Pabbly Connect. Step-by-step tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Accessing Pabbly Connect to Automate WhatsApp Messaging
To send automated WhatsApp messages to your marble and granite business leads, the first step is accessing Pabbly Connect. Start by opening a new tab and navigating to the Pabbly Connect website. If you do not have an account, you can sign up for free, which takes only a couple of minutes.
Once logged in, you will see the dashboard, where you can create workflows. Click on the ‘Access Now’ button under Pabbly Connect. This will direct you to the workflow section where you can manage your integrations effectively.
2. Creating a Workflow for Facebook Leads with Pabbly Connect
Next, you need to create a new workflow to connect Facebook Lead Ads with WhatsApp. Click on the ‘Create Workflow’ button and name your workflow something relevant, like ‘Send Automated WhatsApp Message to Marble and Granite Business Leads’. Select the folder where you want to save your workflow. using Pabbly Connect
- Name the workflow appropriately.
- Select the correct folder for organization.
- Ensure you have the right trigger and action applications selected.
In your workflow, set the trigger application to ‘Facebook Lead Ads’ and the trigger event to ‘New Lead Instant’. This configuration ensures that every time a new lead is captured, the automation will trigger.
3. Connecting Facebook Lead Ads with Pabbly Connect
To connect Facebook Lead Ads with Pabbly Connect, click on ‘Connect’ and then select ‘Add New Connection’. Since you are already logged into your Facebook account, it will automatically detect your account. Click on ‘Continue’ to grant access.
Once connected, you will need to select your Facebook page and lead generation form. For example, if your page is named ‘The Stone Source’, select it from the dropdown. Then, choose the lead form you are using, which can be found under the ‘Instant Forms’ section in the Facebook Business Suite.
4. Sending Automated WhatsApp Messages Using Pabbly Connect
Now that your Facebook Lead Ads are connected to Pabbly Connect, it’s time to set up the action application to send WhatsApp messages. For this, select ‘Wati’ as your action application and the action event as ‘Send Template Message’.
- Select the correct action application (Wati).
- Choose the action event as ‘Send Template Message’.
- Map the WhatsApp number from the lead details.
You will need to connect Wati to Pabbly Connect by inputting the API endpoint and access token from your Wati account. After connecting, map the WhatsApp number retrieved from your Facebook lead details, ensuring that your message template is correctly set up in Wati.
5. Testing the Integration and Finalizing the Setup
Once everything is set up, it’s crucial to test the integration. Click on ‘Save and Send Test Request’ in Pabbly Connect. If successful, you should receive the automated WhatsApp message on the lead’s phone. This confirms that your integration between Facebook Lead Ads and WhatsApp via Pabbly Connect is functioning perfectly.
For verification, check your WhatsApp for the message sent to the lead. It should match the template you set up in Wati, confirming that your automation is working as intended.
Using Pabbly Connect, you can effortlessly send automated WhatsApp messages to your marble and granite business leads. This integration streamlines communication and enhances customer engagement, making it easier for your business to follow up with potential clients.
