Learn how to automate WhatsApp messages for your marble and granite business leads using Pabbly Connect. Step-by-step guide with detailed integration instructions. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Accessing Pabbly Connect for WhatsApp Automation
To automate WhatsApp messages for your marble and granite business leads, you first need to access Pabbly Connect. Open a new tab and search for Pabbly Connect. If you don’t have an account, you can sign up for free, which takes just a couple of minutes.
Once you have logged into your Pabbly Connect account, you will see the dashboard. Here, you can create workflows that connect various applications. Click on the ‘Access Now’ button under Pabbly Connect to start.
In this section, we will create a workflow to send automated WhatsApp messages. Start by clicking the ‘Create Workflow’ button. Name your workflow something descriptive, such as ‘Send Automated WhatsApp Message to Marble and Granite Business Leads’. using Pabbly Connect
  • Select the folder where you want to save your workflow.
  • Click on ‘Create’ to proceed to the workflow setup.
This will bring you to the main workflow area where you can set up triggers and actions. The trigger in this case will be Facebook Lead Ads, and the action will be sending a message via WhatsApp using the WhatsApp API.
The first step in your workflow is to set up a trigger. Choose Facebook Lead Ads as your trigger application and select ‘New Lead Instant’ as the trigger event. This will allow Pabbly Connect to capture new leads from your Facebook ads. using Pabbly Connect
Next, you will need to connect your Facebook account to Pabbly Connect. Click on ‘Connect’ and follow the prompts to authorize access. Once connected, select the Facebook page and lead generation form you are using for your marble and granite business.
  • Choose your Facebook page, for example, ‘The Stone Source’.
  • Select the lead generation form that captures your leads.
After saving these settings, you will need to generate a sample submission from your lead ad form to test the connection.
4. Generating Sample Submission for Testing
To ensure your integration works correctly, you’ll need to generate a sample submission. Head over to Meta for Developers and navigate to the lead ATS R2 debug tool. Here, select your Facebook page and lead form, then click on ‘Preview Form’ to fill in the details.
Fill out the form with test details, such as:
Full Name: Test User Email: [email protected] Phone Number: (WhatsApp number)
Once submitted, return to Pabbly Connect to see if the new lead details have been captured successfully.
5. Sending Automated WhatsApp Messages Using Pabbly Connect
Now that you have captured the lead details, it’s time to set up the action to send an automated WhatsApp message. Choose WhatsApp as your action application and select ‘Send Template Message’ as the action event.
Connect WhatsApp to Pabbly Connect by entering the API endpoint and access token from your WhatsApp API provider. After connecting, map the WhatsApp number from your lead data to ensure the message goes to the right contact.
Select your message template, which should have been pre-approved by WhatsApp. Customize the message content to include variables like the lead’s name.
After setting this up, click ‘Save and Send Test Request’ to send a test message. If successful, you will receive a confirmation response, and you can check WhatsApp to see the automated message sent to your lead.
Using Pabbly Connect, you can automate the process of sending WhatsApp messages to your marble and granite business leads. This integration allows you to respond instantly to new leads, enhancing customer engagement and streamlining your workflow.
