Learn how to automate WhatsApp messages for your cookie business leads using Pabbly Connect and Facebook integration. Step-by-step guide included. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Accessing Pabbly Connect for WhatsApp Automation
To send automated WhatsApp messages to your cookie business leads, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect homepage by typing ‘Pabbly.com/connect’ in your browser. If you are an existing user, click on ‘Sign In’; otherwise, click on ‘Sign Up for Free’ to create a new account.
Once logged in, you will be taken to the dashboard where you can manage your workflows. Here, you can create folders for better organization. To start a new workflow, click on the ‘Create Workflow’ option in the top right corner. This will open a dialog box where you can name your workflow, for example, ‘Send Automated WhatsApp Message to Facebook Leads for Cookie Business’.
2. Setting Up Trigger and Action in Pabbly Connect
In this section, you will set up the trigger and action for your automation. The trigger will be Facebook Lead Ads, which will initiate the workflow when a new lead is generated. Select ‘Facebook Lead Ads’ as your trigger application and choose the trigger event ‘New Lead Instant’.
  • Select ‘Add New Connection’ to connect your Facebook Lead Ads account.
  • Authorize the connection by logging into your Facebook account.
  • Select your Facebook page and the lead generation form associated with it.
After selecting your page and form, click on ‘Save and Send Test Request’. This will prompt you to test the integration by submitting a lead through the Facebook Lead Ads Testing Tool. Once the test submission is completed, the response will be captured in Pabbly Connect.
3. Sending WhatsApp Messages Using Pabbly Connect
After capturing the lead details, the next step is to send a WhatsApp message using the Wati application integrated with Pabbly Connect. In the action application section, select ‘Wati’ and choose the action event ‘Send Template Message’. Then, connect your Wati account by adding a new connection.
To set up the connection, you will need the API endpoint and access token from your Wati dashboard. Copy these details and paste them into the respective fields in Pabbly Connect. Once connected, you will need to map the WhatsApp number from the previous response to ensure the message is sent to the correct lead.
  • Enter the WhatsApp number mapped from the lead response.
  • Select the template name you created in Wati for your cookie business.
  • Fill in the broadcast name and custom parameters required for the message.
Once all fields are filled out, click on ‘Save and Send Test Request’. You will receive a response indicating that the WhatsApp message was successfully sent to the lead.
4. Testing and Verifying the Automation
Testing your automation is crucial to ensure it works as intended. After setting up the trigger and action, you should perform a test submission using the Facebook Lead Ads Testing Tool. This will simulate a new lead submission and allow you to check if the response is captured in Pabbly Connect.
Once the test lead is submitted, you can verify the WhatsApp message delivery by checking the specified number. If the message appears as intended, your automation is successful. It’s essential to ensure that the WhatsApp template used is approved in Wati to avoid any issues during message delivery.
In this way, you can seamlessly connect your Facebook leads with WhatsApp messaging through Pabbly Connect. This automation will help you efficiently communicate with potential customers and keep them informed about your cookie business offers.
5. Conclusion
In conclusion, using Pabbly Connect to automate WhatsApp messages for your cookie business leads is a powerful way to enhance customer engagement. By following the steps outlined, you can ensure that every new lead receives timely information about your offerings. This automation not only saves time but also improves your marketing efforts significantly.
