Learn how to automate WhatsApp messages to Facebook leads for your astrology business using Pabbly Connect. Step-by-step tutorial included! Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
1. Setting Up Pabbly Connect for Your Astrology Business
To send automated WhatsApp messages to Facebook leads for your astrology business, you need to set up Pabbly Connect. First, sign in to your existing account or create a free account on Pabbly Connect. This platform allows you to automate workflows between various applications, making it ideal for integrating WhatsApp and Facebook Leads.
Once logged in, navigate to the Pabbly Connect dashboard. Click on the ‘Create Workflow’ button in the top right corner. In the dialog box that appears, name your workflow as ‘Send Automated WhatsApp Messages to Facebook Leads’ and choose a folder to save this workflow. Click on the ‘Create’ button to proceed.
2. Configuring the Trigger Integration with Facebook Leads
In this section, you will configure the trigger integration in Pabbly Connect. Since Facebook Leads will be your trigger application, select it from the list. The trigger event you need to choose is ‘New Lead Instant’. This means that every time a new lead is captured via Facebook lead ads, the workflow will be activated automatically.
  • Select ‘Facebook Lead Ads’ as the trigger application.
  • Choose ‘New Lead Instant’ as the trigger event.
  • Click on ‘Connect’ to establish the connection.
After establishing the connection, you will need to select the Facebook page associated with your astrology business. Choose the appropriate lead generation form that you have created on Facebook. Once selected, click on ‘Save and Send Test Request’ to ensure that the connection is working correctly.
3. Testing the Lead Integration with Pabbly Connect
Now, it’s time to test the lead integration in Pabbly Connect. To do this, you’ll need to create a test lead using the Meta for Developers tool. This step is crucial to confirm that Pabbly Connect is set up to receive data correctly.
  • Access the Meta for Developers page and navigate to your apps.
  • Select the ‘Lead Ads RTU Debug Tool’ to create a test lead.
  • Fill in the required fields such as email, full name, and phone number, then submit the form.
After submitting the test lead, return to Pabbly Connect to verify that the lead has been captured successfully. You should see the lead details such as email, full name, and phone number displayed in the response section. This indicates that the integration is functioning correctly.
4. Setting Up WhatsApp Automation with Pabbly Connect
In this step, you will set up WhatsApp automation in Pabbly Connect. To do this, select WhatsApp as your action application. The action event you need to choose is ‘Send Template Message’. This action will enable you to send an automated WhatsApp message to the leads captured from Facebook.
To establish a connection between WhatsApp and Pabbly Connect, click on ‘Connect’ and enter the API endpoint and access token from your WhatsApp provider, such as Wati. After successfully connecting, you will need to map the WhatsApp number from the lead details received from Facebook.
By following these steps, you can effectively send automated WhatsApp messages to Facebook leads for your astrology business using Pabbly Connect. This integration streamlines your communication process and ensures timely responses to potential clients, enhancing your service delivery.
