Learn how to send automated WhatsApp messages to Facebook leads for your apparel brand using Pabbly Connect. Step-by-step tutorial with detailed instructions. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To send automated WhatsApp messages to Facebook leads for your apparel brand, you first need to access Pabbly Connect. Start by signing into your Pabbly Connect account. If you are a new user, click on the ‘Sign Up for Free’ button to create an account, which includes 100 free tasks.
Once logged in, navigate to the Pabbly Connect dashboard. Click on the ‘Access Now’ button to reach your dashboard, where you can create a new workflow. This is the starting point for automating your WhatsApp messages to new leads generated from Facebook ads.
In this step, you will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located in the top right corner. In the dialog box that appears, name your workflow something descriptive, such as ‘Send Automated WhatsApp Message to Facebook Leads’.
- Name your workflow clearly to reflect its function.
- Select the appropriate folder for organization.
After naming your workflow, click on the ‘Create’ button. You will then be directed to the main workflow setup area where you will establish the trigger and action for your integration.
3. Setting Up the Trigger for Facebook Leads
To initiate the automation, set up your trigger in Pabbly Connect. Since you want to capture new leads from Facebook, select ‘Facebook Lead Ads’ as your trigger application. The trigger event should be set to ‘New Lead Instant’ to ensure that the workflow runs immediately when a new lead is received.
Next, establish a connection between your Facebook Lead Ads account and Pabbly Connect. Click on the ‘Connect’ button, and if you do not have an existing connection, you will be prompted to create a new one. Follow the on-screen instructions to authenticate your Facebook account.
4. Creating the Action to Send WhatsApp Messages
Now, it’s time to set up the action in Pabbly Connect. In the action window, search for ‘WhatsApp by AI CI’ as your action application. Choose the action event ‘Send Template Message’. This action will send a WhatsApp message to the lead captured in the previous step.
- You need to connect your WhatsApp by AI CI account to Pabbly Connect.
- Provide the API key from your WhatsApp account to establish this connection.
After connecting, you will need to specify the campaign name and select the message template you created earlier. The template should include personalized variables to ensure that the message feels tailored to each lead.
5. Testing the Integration and Sending Messages
Once you have set up the action, it is crucial to test the integration in Pabbly Connect. Click on the ‘Save and Send Test Request’ button to see if the automated WhatsApp message is sent successfully to your test lead. You can create a test lead using the Facebook Lead Ads testing tool.
After submitting a test lead, check your WhatsApp to confirm that the message was sent. If successful, this indicates that your integration is working correctly. Now, whenever a new lead is generated through Facebook Lead Ads, an automated WhatsApp message will be sent seamlessly.
In summary, using Pabbly Connect allows you to automate sending WhatsApp messages to Facebook leads effectively. By following the steps outlined, you can ensure that your apparel brand engages with leads promptly and efficiently. Automating this process not only saves time but also enhances customer experience significantly.
