Learn how to send automated SMS to 99acres leads using Pabbly Connect and ClickSend integration. Step-by-step tutorial for seamless automation. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Accessing Pabbly Connect for SMS Automation
To send automated SMS to 99acres leads, you first need to access Pabbly Connect. This platform allows you to create workflows that integrate various applications seamlessly. If you’re a new user, you can sign up for free and get 100 tasks to start with.
Once logged in, navigate to your dashboard and click on ‘Create Workflow’. Enter a name for your workflow, such as ‘Send SMS to 99 Acres Leads’, and save it in a designated folder. This sets the stage for your automation process.
2. Setting Up the Trigger with 99acres
In this step, you will define the trigger for your workflow using Pabbly Connect. Select 99acres as your trigger application. The trigger event you need is ‘New Leads’. This means every time a new lead is captured on 99acres, it will initiate the workflow.
  • Select 99acres as the trigger application.
  • Choose ‘New Leads’ as the trigger event.
Since 99acres does not allow adding webhook URLs directly, you must contact your account manager to configure this URL in their system. After setting this up, you can capture the webhook response, which includes lead details like mobile number, name, and email.
3. Configuring ClickSend for SMS Sending
Next, you will set up ClickSend as the action application in Pabbly Connect. This action will send SMS to the leads captured from 99acres. Select ClickSend and choose the action event ‘Send SMS’. This will allow you to send messages directly to the leads.
To connect ClickSend with Pabbly Connect, you will need your ClickSend username and API key. You can find these by logging into your ClickSend account, navigating to the developers section, and selecting API credentials. Input these details in Pabbly Connect to establish the connection.
4. Mapping Lead Data for SMS
In this section, you will map the lead data to the SMS fields in Pabbly Connect. This step ensures that the correct information is sent to each lead. Map the mobile number and customize the SMS message. For example, include the lead’s first and last name in the message.
  • Map the mobile number from the webhook response.
  • Customize the SMS message to include the lead’s name.
  • Leave optional fields blank if not required.
Once you have mapped the data, click on ‘Save and Send Test Request’ to verify that the SMS is sent successfully. If you receive a positive response, it indicates that your integration is working correctly.
5. Conclusion: Automating SMS with Pabbly Connect
By following these steps, you can efficiently send automated SMS to leads from 99acres using Pabbly Connect and ClickSend. This integration streamlines communication and ensures timely responses to potential clients. With the power of automation, you can focus on growing your business while Pabbly Connect handles the SMS notifications.
Automating SMS with Pabbly Connect saves time and enhances lead engagement, making your real estate processes more efficient.
