Learn how to sell digital products and automate customer access using Pabbly Subscription Billing and Pabbly Subscription Billing in this detailed tutorial. Learn step-by-step how to configure flexible subscription plans, automate billing cycles, and generate detailed revenue reports without coding knowledge.
1. Accessing Pabbly Subscription Billing for Selling Digital Products
To start selling digital products, you first need to access Pabbly Subscription Billing. This platform allows you to manage subscriptions and automate product access seamlessly. If you don’t have an account, you can sign up for free, which takes only a few minutes.
Once signed in, you will see a dashboard with various options. Here, you can set up your digital product and create a checkout page link for your customers. This is essential for processing payments and managing subscriptions effectively.
To automate the process of providing access to your digital product, you will use Pabbly Connect. This tool integrates various applications, allowing you to create a workflow that connects Pabbly Subscription Billing with Google Drive.
Follow these steps to create your workflow:
  • Click on ‘Create Workflow’ in Pabbly Connect.
  • Name your workflow according to your objective.
  • Select the folder where you want to save your workflow.
Now, you will set up the trigger for your workflow.
3. Setting Up Trigger in Pabbly Subscription Billing
The trigger event is crucial as it determines when the automation starts. In this case, you will select Pabbly Subscription Billing as your trigger application. The specific trigger event will be ‘Successful Payment’. This means that every time a payment is made, the workflow will execute.
To configure this, you need to connect Pabbly Subscription Billing with Pabbly Connect. Follow these steps:
  • Go to your Pabbly Subscription Billing account and navigate to Settings.
  • Add a new webhook and paste the copied URL.
Once done, save the webhook settings to finalize the connection.
4. Integrating Google Drive to Share Product Access
After setting up the trigger, the next step is to configure the action, which will be Google Drive. This is where you will share access to your digital product. In Pabbly Connect, select Google Drive as your action application and choose the event ‘Share a File’.
To complete this setup, you will need to connect your Google Drive account with Pabbly Connect. Here’s how:
Click on ‘Connect’ and sign in to your Google account. Select the file you want to share from your Google Drive. Map the email address of the customer from the previous step.
This ensures that the right customer receives access to the correct product automatically.
5. Testing and Verifying the Integration Workflow
Once you have set up both the trigger and action, it’s time to test the workflow. Make a test payment using the checkout link created in Pabbly Subscription Billing. This will simulate a successful payment and should trigger the workflow.
After completing the test payment, check your Google Drive to verify that the access has been shared with the customer’s email. You should receive a confirmation email in your Gmail account indicating that access has been granted. This confirms that your integration is working as intended.
In this tutorial, we explored how to sell digital products and automate access using Pabbly Subscription Billing and Pabbly Connect. By following the steps outlined, you can streamline your sales process and enhance customer satisfaction.
