Learn how to sell digital downloads with Razorpay and OneDrive by integrating them through Pabbly Connect. Follow this step-by-step tutorial for seamless automation. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for Digital Downloads
To begin selling digital downloads, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website at Pabbly.com/connect. Once there, sign in to your account to reach the dashboard.
After signing in, locate the ‘Create Workflow’ button on the right side of the dashboard. Click on it to initiate the setup process for your digital downloads integration.
In this step, you will create a workflow that connects Razorpay and OneDrive using Pabbly Connect. Name your workflow something relevant, like ‘Sell Digital Downloads with Razorpay and OneDrive’. This helps in identifying the workflow later.
- Select Razorpay as your trigger application.
- Set the trigger event to ‘Payment Captured’.
Once you set these details, Pabbly Connect provides you with a webhook URL. Copy this URL to use it in Razorpay for receiving payment notifications.
3. Setting Up Webhook in Razorpay
Next, it’s time to set up the webhook in Razorpay using the URL generated by Pabbly Connect. Navigate to your Razorpay dashboard and find the ‘Webhooks’ section under settings.
- Click on ‘Add New Webhook’.
- Paste the copied webhook URL.
- Select ‘Payment Captured’ as the active event.
After saving the webhook, go back to Pabbly Connect and perform a test submission to ensure everything is set up correctly. This will help capture the payment data for the next steps.
4. Sending WhatsApp Messages After Payment
The next step in your workflow is to send a WhatsApp message to users after they make a payment. For this, select ‘Interact’ as your action application in Pabbly Connect.
Choose the action event as ‘Send WhatsApp Template Message’. Connect your Interact account by providing the required secret key. Map the required fields such as phone number and template code.
Once the mapping is complete, click on ‘Save and Send Test Request’. This action will send a WhatsApp message to the user confirming their purchase and providing the download link.
5. Finalizing Your Digital Downloads Integration
To finalize your integration, ensure that all details are correctly mapped in Pabbly Connect. Test the entire process by making a mock payment to see if the WhatsApp message is sent correctly.
After testing, you can check your WhatsApp for the confirmation message. This indicates that your integration is successful and ready for real transactions. If everything works as expected, you can start selling your digital downloads seamlessly.
In conclusion, using Pabbly Connect to integrate Razorpay and OneDrive allows for efficient selling of digital downloads. This step-by-step guide has shown how to set up the workflow, ensuring that customers receive their download links via WhatsApp after payment.
