Learn how to recover abandoned ThriveCart carts with SendFox using Pabbly Connect. Follow our detailed tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for ThriveCart and SendFox Integration
To recover abandoned ThriveCart carts using SendFox, the first step is accessing Pabbly Connect. This powerful automation tool allows you to connect different applications without any coding knowledge. Simply visit the Pabbly website and sign in to your account.
After signing in, you will see various Pabbly applications. Click on Pabbly Connect to access the dashboard. From here, you can create workflows to automate tasks between ThriveCart and SendFox, streamlining your marketing efforts.
Once you’re in Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button. You will be prompted to name your workflow; for example, name it ‘Recover Abandoned ThriveCart Carts with SendFox’ and select a folder to save it.
- In this window, you will set a trigger and an action.
In this case, the trigger is your Commander, which will initiate the workflow. Select ThriveCart as your trigger application and choose the trigger event as ‘Cart Abandoned.’ Click on ‘Connect’ to proceed with the integration.
3. Connecting ThriveCart to Pabbly Connect
To connect ThriveCart with Pabbly Connect, you need an API key from your ThriveCart account. When prompted, click on ‘Add a New Connection’ and enter the API key. You can find this key in the API and Webhooks section of your ThriveCart settings.
- Navigate to your ThriveCart settings and click on the API and Webhooks link.
- Generate a new API key and copy it to your clipboard.
Paste the API key into Pabbly Connect and click on ‘Save’. This connection allows Pabbly Connect to monitor your ThriveCart account for any abandoned carts.
4. Setting Up SendFox Integration with Pabbly Connect
After successfully connecting ThriveCart, the next step is to set up SendFox within Pabbly Connect. For the action application, select SendFox and choose the action event as ‘Add Contacts to List.’ This will ensure that any abandoned cart leads are added to your SendFox list for targeted marketing.
Click on ‘Connect’ again and follow the same process to enter your SendFox token. You can find this token in your SendFox account settings under the API section. Copy and paste it into Pabbly Connect and click on ‘Save’ to establish the connection.
5. Mapping Data and Testing the Workflow
With both applications connected through Pabbly Connect, it’s time to map the data from ThriveCart to SendFox. You will need to map fields such as first name, last name, and email from the ThriveCart response to the corresponding fields in SendFox. This mapping allows for dynamic data insertion with every new abandoned cart.
Select the relevant fields from the ThriveCart trigger response. Ensure that the mapped fields correspond correctly to the SendFox contact list.
After mapping the data, click on ‘Save and Send Test Request’ to test the workflow. If successful, you will see the new contact in your SendFox account, confirming that the integration works seamlessly through Pabbly Connect.
In summary, using Pabbly Connect to recover abandoned ThriveCart carts with SendFox automates your marketing efforts effectively. By following these steps, you can ensure potential customers are nurtured through targeted email campaigns, turning them into paying clients.
