Learn how to post Zee Business RSS feeds on X (formerly Twitter) using Pabbly Connect. This detailed tutorial covers every step of the integration process.
1. Setting Up Pabbly Connect for RSS Feeds
To post Zee Business RSS feeds on X, you need to first set up Pabbly Connect. This platform enables seamless integration between your RSS feed and X. Start by searching for Pabbly Connect in your browser and access the landing page.
Once on the Pabbly Connect page, you can either sign in or sign up for a free account. Signing up takes just a couple of minutes and provides you with 100 free tasks each month. After logging in, you will be directed to the dashboard where you can create a new workflow.
Creating a workflow is essential for automating your RSS feed posts to X. In Pabbly Connect, click on the ‘Create Workflow’ button. Name your workflow something descriptive like ‘Post Zee Business RSS Feeds on X’. Then, select a folder to save your workflow in. using Pabbly Connect
  • Your workflow will now have two main boxes: Trigger and Action.
  • The Trigger box is where you set up the RSS feed.
In the Trigger box, select ‘RSS by Pabbly’ as your application. For the Trigger event, choose ‘New Item in Feed’. This event will initiate the workflow when a new RSS feed item is published.
3. Connecting the RSS Feed to Pabbly Connect
After setting up your trigger, you need to connect your Zee Business RSS feed to Pabbly Connect. Click on the ‘Connect’ button and enter the feed URL from the Zee Business RSS feed page. This URL fetches the latest news updates.
To find the feed URL, search for ‘Zee Business RSS feed’ in your browser. Select the specific feed you want, such as market trends, and copy the URL provided. Paste this URL in the designated field in Pabbly Connect.
  • Select the filter type to ensure each item is processed only once.
  • Click on ‘Save and Test’ to receive a response from the RSS feed.
Once the setup is complete, you will receive a response containing the latest news title, publication date, and link, confirming that the connection is successful.
4. Setting Up Twitter Integration in Pabbly Connect
Now that your RSS feed is connected, the next step is to set up the action to create a tweet on X through Pabbly Connect. In the Action box, select X (formerly Twitter) as your application and choose ‘Create Tweet’ as your action event.
Click on ‘Connect’ to establish a connection with your X account. You will need to enter your client ID and client secret, which you can obtain from the X developer portal. Follow the instructions provided in Pabbly Connect to access your developer portal and retrieve these details.
Copy and paste the client ID and client secret into Pabbly Connect. Authorize your app to complete the connection.
Once connected, you can compose your tweet message, including the mapped title and link from the RSS feed response. This ensures that your tweets are always up to date with the latest news.
After setting up the integration, it’s crucial to test the workflow to ensure everything functions correctly. In Pabbly Connect, click on the ‘Save and Test’ button after composing your tweet message. This will send a test tweet to your X account. using Pabbly Connect
Once the test is successful, check your X profile to verify that the tweet has been posted. You should see a tweet containing the latest news from Zee Business, complete with a link for your followers to access more information.
Confirm that the tweet appears as intended with the correct title and link. This automation will now post new RSS feed items to your X account automatically.
With this setup, you can keep your followers engaged and informed about the latest market trends without any manual effort.
In summary, using Pabbly Connect to post Zee Business RSS feeds on X allows for efficient automation of your social media updates. By following the steps outlined, you can ensure that your followers receive timely and relevant news updates effortlessly.
