Learn how to automate posting Zee Business RSS feeds on Telegram using Pabbly Connect. Step-by-step tutorial to integrate RSS and Telegram seamlessly. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Introduction to Pabbly Connect for Telegram Integration
In this tutorial, we will explore how to use Pabbly Connect to post Zee Business RSS feeds directly to Telegram. This integration allows for seamless updates in your Telegram group whenever new RSS feeds are published. By automating this process, you can ensure timely news updates without manual intervention.
To begin, you need to access Pabbly Connect. Visit the Pabbly homepage and either sign in if you are an existing user or sign up for a free account to start using the service. Once logged in, you will be directed to the dashboard where you can create your first workflow.
To create a workflow in Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner of your dashboard. You will be prompted to name your workflow. For this task, name it ‘Post Zee Business RSS Feeds on Telegram’ and select your desired folder, such as ‘Automations’.
  • Click on ‘Create’ to finalize the workflow.
  • You will see the options for setting up triggers and actions.
Next, you need to set up a trigger for your workflow. Choose ‘RSS by Pabbly’ as your trigger application and select the trigger event as ‘New Item in Feed’. This setup will allow Pabbly Connect to monitor the RSS feed for new updates automatically.
3. Configuring the RSS Feed Trigger
After selecting the RSS trigger, you will need to enter the feed URL. To obtain this URL, go to the Zee Business RSS feed page and select a specific category, such as Economy. Copy the feed URL and paste it into the designated field in Pabbly Connect.
  • Set the filter type to ‘Default’ for standard updates.
  • Click on ‘Save and Send Test Request’ to check if the connection is successful.
Upon successful configuration, you will receive a response containing the title, publish date, link, description, and content of the news item. This confirms that Pabbly Connect is correctly capturing the RSS feed updates.
4. Setting Up the Telegram Action
Now that the RSS feed trigger is set up, it’s time to configure the action to send messages to Telegram. Select ‘Telegram Bot’ as your action application in Pabbly Connect. Choose the action event ‘Send a Text Message’ to automate the posting process.
To connect your Telegram account, click on ‘Connect’ and select ‘Add New Connection’. You will need a token from the BotFather on Telegram. Start a chat with BotFather, create a new bot, and copy the token provided. Paste this token back into Pabbly Connect to establish the connection.
After connecting your Telegram bot, you will need to enter the chat ID for the group where you want to post updates. Create a group on Telegram, add your bot as a member, and make it an admin. Copy the chat ID and paste it into Pabbly Connect.
Next, enter the message text you want to send. You can map the RSS feed data to make the message dynamic. For example, include the title and link from the RSS feed in your message. Once everything is configured, click on ‘Save and Send Test Request’ to test the integration.
If successful, you will see the message appear in your Telegram group, confirming that Pabbly Connect has successfully automated the posting of Zee Business RSS feeds. This integration streamlines your news updates, ensuring timely delivery of information to your audience.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the posting of Zee Business RSS feeds to Telegram. This integration simplifies the process of sharing news updates, ensuring that your group stays informed with the latest information effortlessly. By following these steps, you can enhance your Telegram channel with timely updates from RSS feeds.
