Learn how to post Moneycontrol RSS feeds on Telegram using Pabbly Connect. Step-by-step tutorial for seamless integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Accessing Pabbly Connect for RSS Feeds
To post Moneycontrol RSS feeds on Telegram, start by accessing Pabbly Connect. Simply search for Pabbly Connect in your browser and open the landing page. Here, you will see options to either sign in or sign up for free.
If you are a new user, click on ‘Sign up for free’ to get started. Existing users should click ‘Sign In’ to access their dashboard. Once logged in, you will see various Pabbly applications, but for this tutorial, we will focus on Pabbly Connect.
In this step, we will create a workflow in Pabbly Connect. Click on the ‘Create Workflow’ button, which will prompt you to name your workflow. Enter ‘How to Post Moneycontrol RSS Feeds on Telegram’ and choose a folder to save it in.
- Understand that a trigger means when something happens, and an action is what happens as a result.
In the workflow window, select the trigger application as ‘RSS by Pabbly’ and set the trigger event to ‘New Item in Feed.’ This means that whenever a new item is available in your RSS feed, it will trigger the workflow.
3. Setting Up the RSS Feed URL
Next, we need to set up the RSS feed URL in Pabbly Connect. After selecting ‘RSS by Pabbly’ as the trigger, you will be prompted for the feed URL. Open your Moneycontrol RSS feed page and copy the URL for the business news category.
- Paste the copied URL into the feed URL field in Pabbly Connect.
- Click ‘Save and Send Test Request’ to confirm the setup.
After saving, you should see a response indicating that the latest news has been fetched successfully. Remember, the RSS by Pabbly application checks for new data every hour by default, but you can adjust this setting to check every 10 minutes for quicker updates.
4. Connecting Telegram Bot for Notifications
Now, we will set up the action application to send messages to Telegram using Pabbly Connect. Choose ‘Telegram Bot’ as your action application and select the action event as ‘Send a Text Message or Reply.’ This allows you to send messages to your Telegram channel whenever a new RSS item is captured.
Next, you will need to connect your Telegram bot. If you haven’t created a bot yet, search for ‘BotFather’ in Telegram to create a new bot. Once created, copy the token provided by BotFather and paste it into the token field in Pabbly Connect.
5. Finalizing Message Settings and Testing
Finally, in this step, you will finalize the message settings in Pabbly Connect. After connecting your Telegram bot, you will need to enter the chat ID of your Telegram channel. Make sure to add the bot to your channel and give it admin access.
Copy the chat ID and paste it into the corresponding field in Pabbly Connect. Set the text message to include a dynamic title and link from the RSS feed.
After completing these settings, click ‘Save and Send Test Request’ to send a test message to your Telegram channel. You should see the latest business news appear in your channel, confirming that everything is set up correctly.
In this tutorial, we explored how to post Moneycontrol RSS feeds on Telegram using Pabbly Connect. By following the step-by-step instructions, you can automate the process of sharing business news with your subscribers efficiently.
