Learn how to seamlessly post BigCommerce products on Instagram using Pabbly Connect. Follow our detailed tutorial for step-by-step integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
Introduction to Pabbly Connect for BigCommerce and Instagram
Pabbly Connect is a powerful automation tool that allows you to integrate various applications seamlessly. In this tutorial, we will explore how to use Pabbly Connect to post BigCommerce products automatically on Instagram. This integration will help you promote your products effectively and enhance your online presence.
With Pabbly Connect, you can set up workflows that trigger actions based on specific events. For instance, when a new product is added to your BigCommerce store, it can automatically create a post on your Instagram account. This not only saves time but also ensures that your audience is always updated with your latest offerings.
Setting Up Pabbly Connect for BigCommerce and Instagram
To get started, you need to access Pabbly Connect. Open your browser and search for Pabbly Connect, then sign up for a free account if you don’t have one. Once logged in, navigate to the dashboard where you can create a new workflow.
Click on the ‘Create Workflow’ button and name your workflow, for example, ‘Post BigCommerce Products on Instagram’. After naming your workflow, click on ‘Create’ to proceed. This will open a new window where you can set up your trigger and action.
  • Search for BigCommerce as your trigger application.
  • Select the trigger event as ‘New Product’.
  • Connect BigCommerce to Pabbly Connect by entering your store hash key, client ID, and access token.
Now that you have set up your trigger, you can proceed to configure the action step.
Configuring Trigger and Action Steps in Pabbly Connect
After setting up your trigger in Pabbly Connect, you will need to configure the action step. Start by selecting BigCommerce again for your action application. This time, choose the action event as ‘Get Product Details’. This action will fetch the details of the product you just added to your store.
When prompted, connect to BigCommerce using the same credentials you used for the trigger. Once connected, map the product ID from the previous response to retrieve the product details. This mapping ensures that every time you add a new product, the corresponding details will be fetched automatically.
  • Map the product ID from the trigger response.
  • Ensure all necessary product details are retrieved, including name, price, and images.
  • Save your action settings to proceed.
With your action step configured, you can now set up the final step to post on Instagram.
Posting on Instagram Using Pabbly Connect
In the last step of your workflow, select Instagram for Business as your action application. Choose the action event as ‘Publish Photo’. This will allow you to create a new post on your Instagram account using the product details fetched from BigCommerce.
Connect your Instagram account to Pabbly Connect by clicking on ‘Add New Connection’. Authorize the connection by selecting the appropriate Instagram account you want to use. After connecting, you will need to provide the photo URL and caption for your post.
Map the photo URL from the BigCommerce product details. Craft a compelling caption that includes dynamic product information. Test the integration to ensure everything works smoothly.
Once tested successfully, you will see your new product post on your Instagram account, showcasing your latest offerings effectively.
In conclusion, using Pabbly Connect to post BigCommerce products on Instagram automates your marketing efforts and enhances product visibility. By following the steps outlined in this tutorial, you can easily set up this integration and keep your audience engaged with your latest products.
This automated workflow saves time and ensures that your Instagram account is always updated with new products, driving traffic to your BigCommerce store and increasing sales.
