Learn how to integrate URL and PUD using Pabbly Connect in this detailed tutorial. Follow our step-by-step instructions to automate your workflow effectively. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To integrate URL and PUD, first access Pabbly Connect. Begin by visiting the Pabbly website and signing in or signing up for a new account.
Once logged in, you will see the dashboard of Pabbly Connect. Here, you can create a new workflow by clicking the blue button labeled ‘Create Workflow’. This is the first step in setting up your integration.
The next step involves setting up the trigger for your workflow in Pabbly Connect. Choose the application you want to connect, which in this case is the Webhook by P. This will capture responses from your integrated application.
  • Select ‘Webhook by P’ as the trigger application.
  • Copy the provided Webhook URL.
  • Paste this URL into your application settings where you want to send data.
After setting up the Webhook, it’s essential to test the integration. Submit a test response in your application to ensure that Pabbly Connect captures the data correctly.
3. Configuring the Action in Pabbly Connect
After successfully capturing the Webhook response, the next step is to configure the action in Pabbly Connect. Select the action application, which will be Graphy in this case.
Choose the action event as ‘Create Learners’. This is where you will map the data received from the Webhook to create a new learner in Graphy. You will need to connect your Graphy account by providing the API key and Merchant ID.
  • Log into your Graphy account to get the API key.
  • Navigate to the integrations section to find your API key.
  • Copy and paste the Merchant ID from the APIs section.
Once you have entered these details, save the connection to finalize the setup. Now, you can proceed to map the details received from the Webhook to create a new learner.
4. Mapping the Details for the New Learner
In this section, you will map the details received from the Webhook to the fields required to create a new learner in Graphy using Pabbly Connect. Ensure you accurately map the email, name, mobile number, and password.
For mapping, simply click on the respective fields and select the data from the Webhook response. For instance, map the first name and last name together for the full name field.
After mapping all required fields, click on the ‘Save and Send Test Request’ button. This will send the data to Graphy and create a new learner based on the information provided.
5. Verifying the Integration in Graphy
Finally, verify that the integration works as intended. Head over to your Graphy account and check the learners section to see if the new learner has been created successfully.
Refresh the page to see the latest updates. You should see the newly created learner with the details you mapped from the Webhook response in Pabbly Connect.
This step confirms that the integration between URL, PUD, and Graphy using Pabbly Connect is successful. You can now automate this process for future responses.
In this tutorial, we explored how to integrate URL and PUD using Pabbly Connect. By following the outlined steps, you can automate the creation of learners in Graphy efficiently. This integration streamlines your workflow and enhances productivity.
