Learn how to set up integrations between URL and Pap using Pabbly Connect in this detailed tutorial. Follow the exact steps to automate your workflows.
1. Integrate URL with Pabbly Connect
To begin integrating URL with Pabbly Connect, you first need to access your Pabbly Connect dashboard. This platform acts as a bridge between various applications, allowing seamless data flow. Start by navigating to the ‘Triggers’ section in Pabbly Connect.
Once there, search for the URL application. This will be your starting point for setting up the integration. Make sure to select the appropriate trigger event, which will initiate the data transfer to your desired application.
2. Setting Up Webhook in Pabbly Connect
Next, you will set up a webhook in Pabbly Connect. In your Pabbly Connect dashboard, select the trigger event for your integration. For example, if you are using a form submission from a landing page, choose the ‘New Form Submission’ event.
  • Search for the URL application in the trigger section.
  • Select the trigger event as ‘New Form Submission’.
  • Copy the provided webhook URL for further use.
This webhook URL will facilitate the connection between your URL application and Pabbly Connect. Ensure to read any instructions provided in the help desk section to understand how to implement it correctly.
3. Configuring Swipe Pages with Pabbly Connect
After setting up the webhook, the next step is to configure your Swipe Pages account to connect with Pabbly Connect. Go to the Integrations section in your Swipe Pages dashboard. Here, you will create a new workflow that will utilize the webhook you copied earlier.
While setting up this workflow, drag and drop the ‘Form Submitted’ trigger to start your automation. After that, select the specific form you want to connect, ensuring it matches the one you created in your URL application.
4. Testing Your Integration in Pabbly Connect
Once your integration is configured, it’s time to test it in Pabbly Connect. Fill out the form you set up in Swipe Pages with test details. For example, enter a name, email, and phone number, then submit the form.
  • Ensure that the data submitted matches the fields you set in the webhook.
  • Check Pabbly Connect to see if the test response has been captured correctly.
Upon successful submission, you should see the response reflected in your Pabbly Connect dashboard. This confirms that your integration is working as intended.
5. Activating Your Workflow in Pabbly Connect
After testing, the final step is to activate your workflow in Pabbly Connect. Go back to your Swipe Pages account and click on the ‘Save Changes’ button. Then, activate the workflow to ensure it captures all future form submissions.
With your workflow activated, any new form submissions will automatically trigger data transfer to Pabbly Connect. This real-time data capture ensures that you can manage your submissions efficiently and effectively.
By following these steps, you can successfully integrate URL and Pap using Pabbly Connect. This platform offers a robust solution for automating workflows and managing data between various applications.
