Learn how to seamlessly integrate Thrivecart and Teachable using Pabbly Connect for automated course enrollment. Follow our step-by-step tutorial now! Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Accessing Pabbly Connect to Start Your Integration
To begin your integration process, you first need to access Pabbly Connect. This platform serves as the central hub for automating your workflows between Thrivecart and Teachable. Sign up for a free Pabbly account to get started.
Once you have signed up, log in to your Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. This is where you will set up the automation that links your Thrivecart product purchases to Teachable course enrollments.
In this step, you will configure the trigger in Pabbly Connect that starts the automation. The trigger for this integration is a product purchase in Thrivecart. Select Thrivecart as your trigger application and choose the ‘Product Purchase’ event.
  • Select Thrivecart as the trigger application.
  • Choose ‘Product Purchase’ as the trigger event.
  • Click on the ‘Connect’ button and add a new connection.
After connecting, you will need to enter your Thrivecart API key. You can find this key in your Thrivecart account under the ‘Settings’ section. Once you have pasted the API key into Pabbly Connect, save your changes to complete the trigger setup.
3. Testing the Thrivecart Connection
With the trigger set up, it’s time to test the connection between Pabbly Connect and Thrivecart. After saving the trigger setup, click on the ‘Save and Send Test Request’ button. This action will allow Pabbly Connect to listen for any purchases made through Thrivecart.
To perform a test submission, manually complete a purchase using test card details on your Thrivecart checkout page. Once the purchase is completed, Pabbly Connect will capture the data from this transaction, showing details such as the student’s name and email address.
Now that we have tested the Thrivecart connection, the next step is to set up the action in Pabbly Connect. This action will enroll the student in a specified course on Teachable. Search for Teachable in the action application section and select the ‘Enroll User in Course’ action event.
Connect to your Teachable account by entering your email, password, and the subdomain of your Teachable site. The subdomain can be found in the URL of your Teachable admin panel. Once connected, select the course in which you want to enroll the student.
  • Map the student’s email and name from the data captured in the previous step.
  • Leave the password field blank for the student to set later.
  • Click ‘Save and Send Test Request’ to finalize the action setup.
Once you receive a positive response, check your Teachable account to see that the student has been successfully enrolled in the course.
5. Finalizing Your Automation with Pabbly Connect
After completing all the steps, your automation is now set up using Pabbly Connect. This integration will automatically enroll students into your Teachable courses whenever they purchase through Thrivecart. You only need to set it up once, and it will run seamlessly in the background.
To ensure everything is functioning correctly, monitor the workflow in Pabbly Connect. You can view the logs and check for successful enrollments. With this automation in place, you can focus more on creating content for your courses while Pabbly Connect handles the enrollment process.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Thrivecart and Teachable for automated course enrollments. By following these steps, you can streamline your enrollment process and save valuable time. Experience the power of automation with Pabbly Connect today!
