Learn how to use Pabbly Connect to automate the integration between System.io and Aweber for seamless subscriber management. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To begin the integration process, you must first access Pabbly Connect. Open your browser and search for Pabbly Connect. This will take you to the landing page where you can either sign in or sign up for free.
If you are a new user, click on the ‘Sign Up for Free’ button to create your account. This process takes only a few minutes and grants you 100 free tasks to explore the software. Existing users can simply sign in to their accounts.
After logging into Pabbly Connect, navigate to the dashboard where you can view all your created workflows. To create a new workflow, click on the ‘Create Workflow’ button located at the top right corner of the screen.
  • Click on ‘Create Workflow’.
  • Provide a name for your workflow, such as ‘Create Aweber Subscriber from System.io Form Submission’.
  • Select the folder to save your workflow.
After naming your workflow, click on the ‘Create’ button. You will see two windows open for Trigger and Action. The Trigger is what starts the workflow, while the Action is the response to that trigger.
In this step, you will set up the Trigger using Pabbly Connect. Choose ‘System.io’ as your trigger application and select the trigger event as ‘Contact Just Subscribed to a Form’. This means that whenever a new form is submitted in System.io, it will initiate the workflow.
Upon selecting the trigger event, Pabbly Connect will provide you with a Webhook URL. Copy this URL as you will need it to connect System.io with Pabbly Connect.
  • Select ‘System.io’ as the trigger application.
  • Choose the trigger event ‘Contact Just Subscribed to a Form’.
Now, you are ready to set up the corresponding action in System.io that will send data to this Webhook URL.
4. Configuring System.io to Send Data to Pabbly Connect
Next, you will configure System.io to send form submissions to Pabbly Connect. Log in to your System.io account and navigate to ‘Automations’. From there, click on ‘Rules’ and then select ‘Create New Rule’.
In the new rule setup, select the trigger event as ‘Funnel Step Form Subscribed’ and choose the funnel you want to use. After setting this up, click on the plus sign under Action and select ‘Send Webhooks’.
Select ‘Funnel Step Form Subscribed’ as the trigger event. Choose the funnel that contains your form. Paste the Webhook URL copied from Pabbly Connect.
Once you save the rule, System.io will be set up to send data to Pabbly Connect whenever a form is submitted.
5. Finalizing the Action to Add Subscribers in Aweber
The final step is to set up the action in Pabbly Connect to add a new subscriber in Aweber. Select ‘Aweber’ as your action application and choose the action event as ‘Add or Update Subscriber’. After that, click on ‘Connect’ and log into your Aweber account.
Once connected, map the fields from the System.io form submission to the appropriate fields in Aweber, like Full Name and Email. Make sure to use the mapping feature to ensure data flows seamlessly from System.io to Aweber through Pabbly Connect.
Select ‘Aweber’ as the action application. Choose the action event ‘Add or Update Subscriber’. Map the necessary fields from System.io to Aweber.
After setting this up, test the workflow by submitting a new form in System.io and check if a new subscriber is created in Aweber successfully.
In this tutorial, we successfully integrated System.io with Aweber using Pabbly Connect. This process allows for automatic subscriber management, enhancing your marketing automation efforts. By following these steps, you can streamline your workflow and improve efficiency.
