Learn how to automate subscriber creation in Kit using Pabbly Connect and P Form Builder. Step-by-step tutorial with detailed instructions. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating P Form Builder with Kit, you first need to access Pabbly Connect. Begin by visiting the Pabbly Connect website where you can log in to your existing account or sign up as a new user. If you’re a new user, you can enjoy 100 free tasks every month.
Once logged in, you will see the dashboard displaying all Pabbly applications. Here, you will select Pabbly Connect by clicking on the ‘Access Now’ button. This will take you to the Pabbly Connect dashboard where you can create workflows to automate your tasks.
After accessing Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button located at the top right corner of your dashboard. A dialog box will appear prompting you to name your workflow and select a folder for organization purposes.
For this integration, name your workflow ‘Create Kit Subscriber on P Form Builder Submission’ and select the appropriate folder where you want to save it. After entering the details, click on the ‘Create’ button. You will now see two sections: Trigger and Action, which are crucial for setting up your automation.
Setting Up the Trigger in Pabbly Connect
In this step, you will set up the trigger application using Pabbly Connect. Select ‘P Form Builder’ as your trigger application and choose the event as ‘New Form Submission’. This event will trigger the workflow whenever a new submission is made through your form.
Once you select the trigger, Pabbly Connect will generate a unique webhook URL. Copy this URL as it will be used to connect P Form Builder with Pabbly Connect. Next, go to your P Form Builder account and navigate to the integration settings to create a new webhook.
  • Open your P Form Builder account.
  • Navigate to the integration section.
  • Create a new webhook and paste the copied URL.
After saving the webhook, return to your Pabbly Connect workflow and test the connection by submitting a test form. This will ensure that the trigger is set up correctly and Pabbly Connect captures the submission data.
Adding an Action Step in Pabbly Connect
With the trigger successfully set, the next step is to add an action in Pabbly Connect. For the action application, select ‘Kit’ and choose the event as ‘Add Subscriber’. This action will automatically add new subscribers to your Kit account whenever a form is submitted.
You will be prompted to connect your Kit account by entering the API key and secret. To find these details, log into your Kit account, go to settings, and then navigate to the developer section to copy the API key and secret. Paste these into the respective fields in Pabbly Connect.
  • Log into your Kit account.
  • Navigate to settings and then to the developer section.
  • Copy the API key and secret and paste them into Pabbly Connect.
After connecting Kit, map the subscriber fields such as first name, last name, email, and mobile number using the data captured from the form submission. This mapping ensures that the correct information is sent to Kit every time a new member signs up.
Testing the Integration in Pabbly Connect
Now that you have set up the action step, it’s time to test the entire integration process using Pabbly Connect. Submit a test entry in your P Form Builder form again, ensuring all required fields are filled out. This will initiate the workflow you created.
After submitting the form, check your Kit account to see if the new subscriber has been added successfully. Refresh the subscriber list in Kit, and you should see the new entry reflecting the details you submitted. This confirms that Pabbly Connect has successfully automated the process of adding subscribers.
Repeat this test with different entries to ensure that the integration is functioning correctly every time a form is submitted. This automation saves time and reduces errors in manually adding new subscribers, showcasing the efficiency of using Pabbly Connect.
In this tutorial, we explored how to integrate P Form Builder with Kit using Pabbly Connect. By automating subscriber creation, you can streamline your workflow and enhance communication with new members. This process not only saves time but also ensures accuracy in your subscriber management.
