Learn how to automate notifications for Mojo payments on Slack using Pabbly Connect in this step-by-step tutorial. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start using Pabbly Connect, you first need to visit the website by typing Pabbly.com/connect in your browser. This platform is essential for integrating various applications, including Mojo and Slack.
Once on the Pabbly Connect page, you have the option to sign in if you are an existing user or sign up for free if you are new. Signing up grants you 100 free tasks monthly, allowing you to explore the platform’s capabilities.
After signing into Pabbly Connect, navigate to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button and name your workflow, for example, ‘Notify Team on Slack Channel for Instamojo Payment.’ Select a folder to save your workflow.
- Two boxes will appear: one for Trigger and one for Action.
- Select ‘Instamojo V2’ as the Trigger application.
In this workflow, the trigger will be a new payment received via Instamojo, and the action will be sending a notification to Slack. This setup allows your team to be instantly informed of new payments.
3. Setting Up the Trigger for Instamojo Payments
To set up the trigger in Pabbly Connect, select the event ‘New Sale’ from the trigger options. This action will initiate the workflow whenever a new payment is made.
After selecting the trigger event, a webhook URL will appear. This URL is crucial as it serves as a bridge between Instamojo and Pabbly Connect. Copy this URL and head to your Instamojo account to set it up.
- Access the product you want to connect in Instamojo.
- Navigate to the Advanced options and paste the webhook URL.
- Save the changes to establish the connection.
Once the webhook URL is saved, return to Pabbly Connect and wait for the webhook response. To test the connection, perform a test transaction on your product page to ensure the workflow is triggered correctly.
4. Setting Up Slack to Notify Team
Now that the trigger is set, the next step in Pabbly Connect is to configure Slack as the action application. Select Slack as your action and choose the ‘Send Channel Message’ option.
If you do not have an existing connection, click on ‘Add New Connection’ and follow the prompts to connect Slack with Pabbly Connect. Enter your token type (user or bot) and authorize the connection.
Select the appropriate Slack channel for notifications. Draft the message format you want to send to your team. Use the mapping feature to dynamically insert payment details.
By using mapping, you ensure that every new payment’s details are automatically included in the message sent to Slack, making your notifications dynamic and relevant.
5. Testing the Integration and Verification
After configuring the Slack action in Pabbly Connect, it’s time to test the integration. Click on ‘Save and Send Test Request’ to send a sample notification to your selected Slack channel.
Check your Slack channel to verify that the message has been received. The message should include the payment details such as the name, phone number, email, and purchase amount, confirming that the integration works correctly.
Ensure that the message format matches your drafted message. If the message appears correctly, the integration is successful. You can now automate notifications for future payments.
With everything set up, your team will be automatically notified on Slack whenever a new payment is made through Instamojo, streamlining your communication process.
In this tutorial, we explored how to use Pabbly Connect to automate notifications for Mojo payments on Slack. By following the steps outlined, you can ensure your team stays updated with real-time payment information, enhancing your operational efficiency.
