Learn how to seamlessly integrate MailChimp with Flexi Funnels using Pabbly Connect. Follow our step-by-step tutorial for automation. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start integrating MailChimp with Flexi Funnels, you first need to access Pabbly Connect. This platform enables seamless automation between different applications. Visit the Pabbly Connect website and sign in or sign up for a free account.
Once logged in, you will be directed to the Pabbly Connect dashboard. Here, you can create workflows that connect various applications, such as MailChimp and Flexi Funnels. This is the first step in automating your subscriber creation process.
After accessing the dashboard of Pabbly Connect, click on the ‘Create Workflow’ button. This will open a dialog box prompting you to name your workflow. Name it something descriptive, like ‘Create MailChimp Subscriber on Flexi Funnels Form Submission’.
  • Select a folder where you want to save the workflow.
Upon creation, you will see options for setting up a trigger and an action. The trigger application will be Flexi Funnels, and the action application will be MailChimp. This setup is essential for automating the subscriber creation process.
3. Setting Up Trigger from Flexi Funnels
The next step involves setting up the trigger in Pabbly Connect. Choose Flexi Funnels as your trigger application. You will then need to select the trigger event, which in this case is ‘New Form Submission’. This event starts the workflow whenever a new form is submitted.
After selecting the trigger event, you’ll receive a webhook URL. Copy this URL as it will be used to connect Flexi Funnels with Pabbly Connect. Now, navigate to your Flexi Funnels account and access the project settings where you want to set up the webhook.
  • Edit the page settings and find the option to connect a webhook.
  • Paste the copied webhook URL and name your webhook.
  • Save the settings to establish the connection.
Once saved, return to Pabbly Connect, where it will indicate that it is waiting for a webhook response. This means your trigger is now set up and ready to receive data from Flexi Funnels.
4. Configuring the Action in MailChimp
Now that your trigger is set up, the next step is to configure the action in Pabbly Connect. Select MailChimp as your action application and choose the action event ‘Add New Member with Custom Fields’. This action will create a new subscriber in MailChimp based on the data received from Flexi Funnels.
To connect your MailChimp account, you will need to enter your API key and data center. You can find these details in your MailChimp account under ‘Profile’ > ‘Extras’ > ‘API Keys’. Generate a new API key if necessary and copy it into Pabbly Connect along with your data center information.
Map the email address and other relevant fields from the previous step’s response. Fill in additional fields such as first name and last name, mapping them accordingly.
After mapping all necessary fields, click on ‘Save and Send Test Request’. If everything is set up correctly, you should receive a positive response indicating that the subscriber has been successfully created in MailChimp.
To ensure everything works smoothly, it’s time to test the integration set up in Pabbly Connect. Go back to your Flexi Funnels page and perform a test submission with dummy data. This will trigger the workflow you created.
After submitting the form, return to Pabbly Connect to check if the webhook has received the data. You should see the details from your test submission logged in Pabbly Connect. If the test is successful, you can confidently say that your integration is working.
Verify that the subscriber appears in your MailChimp audience list. Check that all mapped fields are correctly populated.
With successful testing, your workflow is now fully operational. You can automate the process of creating subscribers in MailChimp whenever a form is submitted in Flexi Funnels using Pabbly Connect.
In this tutorial, we explored how to integrate MailChimp with Flexi Funnels using Pabbly Connect. By following the steps outlined, you can automate subscriber creation efficiently. This integration enhances your marketing efforts and streamlines your processes.
